fuel system help?
Old Oct 30, 2013 | 10:40 AM
darnie's Avatar
Default fuel system help?
i have a 2004 gmc sierra with a 5.3 lm7 with a return-less fuel system. im currently running stock fuel rails, siemens deka 80lb injectors , walbro 400 fuel pump with the hotwire kit. im wanting to put in a boost controlled fuel pressure regulator but im not sure what one to go with. i been looking at the areomotive universal ones?
ive also been trying to cram info on all this but from what i gather is i will have to convert the system to a return style system and may also have to get some new fuel rails? if thats the case i think i got the rails picked out and i know if i need to convert it i can use a -6 line. but if i have to do this im not quite sure how to hook it up and run it. also dont know what all fittings id need and how long of hose? i appreciate the help guys.
Old Oct 31, 2013 | 05:15 PM
darnie's Avatar
im going to try ad have it tuned for 8psi for now until i can afford to do a returnless set up so far ive come up with this.
http://www.summitracing.com/parts/pf...make/chevrolet
http://www.summitracing.com/parts/maa-4305m/overview/
and a -6an line for the return.
ideas?
Old Oct 31, 2013 | 05:35 PM
Atomic's Avatar
I have a gauge for that
https://www.performancetrucks.net/fo...ersion-471680/
Old Nov 1, 2013 | 08:37 AM
darnie's Avatar
do you by chance have any pictures on how you modded the top of the bucket and how you ran the return line? i know i wont need the bulkhead and stuff inside the bucket because im running the single. also what regulator did you end up going with?
Old Nov 1, 2013 | 10:49 AM
Atomic's Avatar
I drilled a hole in the top for the bulkhead and wires. Thats it.
Return line follows the feed line that followed the factory fuel line path.
Aeromotive 13101 I think...
Old Nov 1, 2013 | 11:00 AM
AndysC3's Avatar
The regulator you posted has -8an in/out. Look for ones with a -6in/out. Or I could sell you mine since it's going to be awhile until I get a new motor for mine
Old Nov 1, 2013 | 01:38 PM
gamble686's Avatar
What about building a quality feed line and using the stock feed line as a return line?
Old Nov 1, 2013 | 02:25 PM
Atomic's Avatar
Done it that way plenty of times, works fine.
Old Nov 1, 2013 | 09:38 PM
darnie's Avatar
Would it be better to just do that use the feed as a return?
Old Nov 1, 2013 | 09:52 PM
BlackGMC's Avatar
Resident Retard
Here is mine.
https://www.performancetrucks.net/fo...re-kit-510664/
