Trick Turbo Kit- now what???
Old Aug 10, 2019 | 12:49 PM
DeucesALLin's Avatar
Originally Posted by FFDP
4.8 trucks kept the 4L60e transmission.
I'd get larger injectors right off the bat, go with some 50's or 60's at least. You can find stock take off 6.2 injectors that are 52lb/hr. On pump gas with a decent air fuel ratio they should make around that 450-500hp.
Ive got some decaps that flowed +90lbs on their way, but am curious how much boost I can run STOCK with the factory PWM pump and factory Fuel Pressure Regulator setup, with HP Tuners
Old Aug 10, 2019 | 12:52 PM
Originally Posted by arthursc2
Bigger exhaust wouldn't hurt, but otherwise crank up the boost and let her eat
and be prepared to swap that trans sooner than later!
I will be running the Trick downpipe open for a while.
I have 2 TH400s ready to go in, one is waiting on hard parts and a gear vendors unit, the other is GTG but kind of want to wait for a new driveshaft until my new rear end is in. With that said- do I need an external FPR to just run 6 or 8psi? Id like to have it running ALL STOCK and under boost while getting stuf ready for the next step
Old Aug 10, 2019 | 12:54 PM
Originally Posted by hunterbohanan23
George Conroy claims the FF pump is good for 700's rwhp in his old 408 twin turbo truck. Upgrade injectors and you'd be fine. Throw a trans cooler on that 6 speed to help it last. Good tune and you'll be ready to have a 500 rwhp truck with ease
500rwhp on factory fuel setup, not even an external regulator?
Old Aug 10, 2019 | 03:16 PM
RySmDPT14's Avatar
I would seriously get bigger injectors, and better pump with a boost ref regulator. I pushed my flex injectors as much as I could and at 8 psi they were. 120%DC and still lean. Did my own 525 pump set up, aeromotive regulator and now it’s nice and happy. But hey what do I know....
Old Aug 11, 2019 | 02:51 PM
03sierraslt's Avatar
Good luck with the decaps, don’t be shocked when you have a hole go lean and pop.
Old Aug 11, 2019 | 10:11 PM
MikeGyver's Avatar
Originally Posted by DeucesALLin
,.........Once its finished, it will get installed with a GearVendors unit,,........
How do you plan to control the overdrive? Some way to get it to automatically shift at a certain speed would be cool. And maybe a WOT switch to keep it from going into OD. Just some thoughts I had when I had a truck with a turbo 400 and fantasized about getting a Gear Vendors OD
Old Aug 12, 2019 | 05:06 AM
smokinlmm's Avatar
I've got over 600 rwhp on factory fuel system...
Old Aug 12, 2019 | 08:00 AM
Choda's Avatar
All you need is 60lb injectors. Put the 10 psi spring in the WG and have fun.
Old Aug 12, 2019 | 04:10 PM
RySmDPT14's Avatar
Go hot up HPTuners forum, you will get some good info on what you plan to do from people that tune this stuff first hand.
Old Aug 12, 2019 | 05:16 PM
Talk to who ever is tuning it before you buy injectors. Injectors without good data are worthless.
4.8lowks
Jan 25, 2019 05:09 PM
Blackout-88
Nov 15, 2017 10:43 AM
A4edwin
May 2, 2016 09:14 AM
MarkGMCCrew
Aug 11, 2014 05:33 PM
svtlightning02
22
Oct 16, 2011 11:48 AM
