Trick Turbo Kit- now what???
Ive got some decaps that flowed +90lbs on their way, but am curious how much boost I can run STOCK with the factory PWM pump and factory Fuel Pressure Regulator setup, with HP Tuners
I have 2 TH400s ready to go in, one is waiting on hard parts and a gear vendors unit, the other is GTG but kind of want to wait for a new driveshaft until my new rear end is in. With that said- do I need an external FPR to just run 6 or 8psi? Id like to have it running ALL STOCK and under boost while getting stuf ready for the next step
500rwhp on factory fuel setup, not even an external regulator?
I would seriously get bigger injectors, and better pump with a boost ref regulator. I pushed my flex injectors as much as I could and at 8 psi they were. 120%DC and still lean. Did my own 525 pump set up, aeromotive regulator and now it’s nice and happy. But hey what do I know....
How do you plan to control the overdrive? Some way to get it to automatically shift at a certain speed would be cool. And maybe a WOT switch to keep it from going into OD. Just some thoughts I had when I had a truck with a turbo 400 and fantasized about getting a Gear Vendors OD
MarkGMCCrew
Aug 11, 2014 05:33 PM
svtlightning02
22
Oct 16, 2011 11:48 AM
