Trick turbo installation and review
Old Feb 18, 2016 | 04:45 PM
  #111
crashmymax's Avatar
Originally Posted by George C....
Your maf has 3 wires the IAT has 2 wires
You have 3 wires
Ground
5v
Signal
Start probing to see what ya dont have
What have you done? Did you need to extend the maf wiring?
No did not extend the wires just moved them. I will be picking up the truck tonight or first thing in the morning so i can start testing. So the IAT and MAF are in the same sensor? 2 wires controling the IAT and 3 control the MAF. So i would turn the key on probe the ground wire then one wire should read 5v. What will the signal wire read?
Old Feb 18, 2016 | 05:03 PM
  #112
George C....'s Avatar
Formerly ScreamingL
Signal is from the pcm
Old Feb 18, 2016 | 05:05 PM
  #113
crashmymax's Avatar
Will it have a certin voltage to know if it is correct?
Old Feb 19, 2016 | 07:58 AM
  #114
mdwatts11's Avatar
Is the maf installed with the airflow in the correct direction?
Old Feb 19, 2016 | 08:39 AM
  #115
Choda's Avatar
^^ good point. itll take 3 seconds to check.
I have the stock MAP and MAF sensors and my tuner had no problem tuning it.
Originally Posted by GXPJAY
Only valve springs, 72/75mm Turbonetics BB, 4x4 ran in 2wd on dyno of course through the 4L80E, 94 octane pump (we don't have 93 in Canada just 91 or 94) and with meth with the cutout open it's all part of the kit.
OK I can see that.
Good turbo, springs to hold the pressure and meth.
  #116
crashmymax's Avatar
Yes double checked that. Getting the truck later this morning hopefully figure something out.
Old Feb 19, 2016 | 10:13 AM
  #117
crashmymax's Avatar
Not sure whats up with the MAF i only need the MAP since im using dash logic and not a boost gauge for reading boost.
I was just going to get a new sensor but they wont let me return it if its not the problem. So i need to make sure thats the problem before buying it. Getting the truck in about an hour so i can start working on it.
Tuner is now thinking ill be right around 400hp on 91 octane. Little disappointed was hoping for 450.
Old Feb 19, 2016 | 10:43 AM
  #118
Formerly ScreamingL
Maf wont read unless its running
And maf can only go one way
Old Feb 19, 2016 | 02:02 PM
  #119
crashmymax's Avatar
Turns out to be bad sensor. I guess the confusion was he (tuner) was not getting a code so he figured it was more likely a wiring issue on my part. This morning it finally threw a code.
next available time to get the truck back in for tuning is the 29th. He said it was good to go just not to go WOT or above 5000rpm. He has it dialed in for the most part. I dont think it is though did some wired spitting and sputtering if i got on the throttle at all. Nice easy acceleration its fine. Wonder if adding a working MAF changed how it runs, so now its not as dialed in as it was. Thats all over my head. Now i have to drive it around for another week and a half with out being able to enjoy my new turbo.
he did not do anything with the transmission said the can tune from diablo i 2 was fine. Does that sound right?
Definitely disappointed i cant be out driving it like i want to. Also do you guys leave traction control on or disable it? Mine kicked in once shifting to second and i was not on it hard at all.
Old Feb 19, 2016 | 02:57 PM
  #120
Choda's Avatar
i would think someone doing a custom tune on your truck would have at least said something about the can tune.... but its possible the diablo guys nailed it.
i would ***** foot it until it is completely tuned. Or not at all.
I didnt know you could disable TC. i just use the button. Mine sometimes breaks the tires loose from 1-2 under reg driving but its nothing to worry about.
