Trick turbo installation and review
Old Feb 19, 2016 | 04:26 PM
  #121
crashmymax's Avatar
I dont know if you can disable TC. was just wondering if it constantly being activated would cause somthing to wear out prematurely.
Definitely be granny driving most of the time but he did ask me to drive it all week and take notes of everything it does so he can finish the tune in one shot.
Old Feb 19, 2016 | 04:43 PM
  #122
JordanH's Avatar
Restricted
Originally Posted by crashmymax
not sure I understand this my MAF has 5 wires. The tuner is done he does not have time to track down this problem so its up to me. with his HP tuner connected and the truck running he gets zero. with my diablo I 2 connected still getting zero. the computer recognizes that it is there because when the sensor is unplugged is it says failed. plug it back in and its not failed. what could I have done to cause this? checked all the wires for breaks all looks good.
Your MAF has 5 wires.... And the two tan ones on the end are the IAT intake air temp wires.... Your IAT is built into your MAF
I guess diffrent tuners do things diffrent?.... Because I'm still running my factory map sensor, but I did change my MAF to the ls3/7 card style...
Old Feb 19, 2016 | 04:47 PM
  #123
JordanH's Avatar
Restricted
My TC is perminantly disabled..... Truck did it all on its own at some point?.... Never really cared to see why, I think they install that stuff for high school girl drivers or something? You've graduated to a turbo truck, no need for it now!
Old Feb 19, 2016 | 05:26 PM
  #124
George C....'s Avatar
Formerly ScreamingL
Listen....you can run boost with stock map but when logging it wont read past 120kpa no matter what...switching to a zr1 map will allow you to read boost in scanner
The map in this case has no effect on tune
The plug for the Maf has a total of 5 wires. 3 are for the maf and 2 are for IAT
Old Feb 19, 2016 | 07:59 PM
  #125
JordanH's Avatar
Restricted
So is this a good or bad thing? What are the advantages of being able to read boost in a scanner?
I'm fully aware of this, That's why I posted my answer.... I didn't think "crashmymax" was aware of what you were trying to explain to him...
Old Feb 20, 2016 | 09:22 AM
  #126
crashmymax's Avatar
Must not have made it clear how i was posting it sorry. I was only looking for a 3 bar map for dash logic. It will be my boost gauge but takes all its readings from the existing sensors. I believe are stock map can only read somewhere around 3 to 7 psi so i need a 2 or 3 bar map since i am currently running 10psi. Thanks for all the help guys
Old Feb 20, 2016 | 12:24 PM
  #127
Formerly ScreamingL
reads 120 kpa which is 3psi ish
Old Feb 20, 2016 | 02:24 PM
  #128
crashmymax's Avatar
thats good to know i just installed the vette MAP so if i get a reading of 4psi or higher i will know it's working. Don't want to go over 4-5psi since truck is not running very good. I wonder if putting the new MAF has made run worse since it was tuned with a non working MAF.
I was thinking of swapping the old one back in and seeing how it runs.
Old Feb 20, 2016 | 02:31 PM
  #129
mdwatts11's Avatar
So just to confirm. Going to a 2 or 3 bar in an NNBS doesn't require a retune? I might go ahead and do this in prep for the turbo.
Old Feb 20, 2016 | 02:37 PM
  #130
crashmymax's Avatar
I am not sure if it does or not. Hopefully George C does. My redneck test is to go drive it and see if i get readings over 4psi this would lead me to believe its working knowing the factory MAP can only read 3psi ish.
