thermostats ???
just wanted to know what you guys run, 160 or 180, im still running a stock thermostat and want to see what you guys have seen in difference between the two in drivability and performence
just woundering on how much it would help with knock too, still getting knock at 10psi with out meth
im running the 160 deg. tstat now and it has helped alot with the under hood temps...driving in this 100 deg heat all day my temps are 176 instead of 200 and i have a turbo blanket along with insulated thermo tube for my 3" intake coming from the ic to the tb to battle heat soak from radiator and ect...
Random, not sure if u mean hotrod04 or me? I live in MI, not TX. I still need quick heater/ warmup in cold weather. I, myself, might try a 170*. As my truck stands, w/ present stock t-stat, couldn't some hp gains be made just by using HPT to change when fans go on/ off?
And no you won't gain anything by changing your fan settings. If you have them tuned right(or at least like everyone else), they should almost never come on. I live in Texas and the only time i've seen my fans come on is when the a/c is on.
I was speaking to anyone interested in a 180* t-stat. You're just wasting your money. Why spend $30+ to make your engine run at 190* instead of 197*. It doesn't matter where you live, a 160* stat will not make your truck run at 160* and a 180* will not make your truck run a 180*.
Before I go changin settings or swappin t-stats, I'll do e-fans.
I understand that dude, but the stock t-stat is considered a 187* thermostat. Why not get the 160* one. It will make your truck run about 180* no matter what climate you are in.
