Speed density HELP
Old May 5, 2010 | 11:00 AM
04redsilverado's Avatar
Unhappy Speed density HELP
I have a 5.3 silvy and want to convert over to SD from what I could find with a search is simply buying a 2 Bar map and a tune and Thats it? What about IAT What about the wiring for the MAF I just need to know what I need to do I have asked so many people and so many different answers I just dont want to look like an idiot when I go try to have this thing tuned and I have cut all my wires and thank you for your help!
Old May 5, 2010 | 11:33 AM
BigKID's Avatar
If you are removing the MAF completely, you will need to add an IAT sensor and splice the tan wire from your MAF connector to it. The remainder of your MAF wiring will simply be tucked away somewhere. If you leave the MAF in place, the IAT sendor built into the MAF will still function with the airflow features tuned out.
Old May 5, 2010 | 11:52 AM
Atomic's Avatar
I have a gauge for that
Why are you going to speed density? Do you have boost? If you arent going to 2bar just set the fail frequency to 0 and its in speed density, dont cut anything.
Old May 5, 2010 | 12:11 PM
Yes I am finishing up my turbo build It is presently set up for 10lbs and I made no provisions for MAF I wanted to do completely away with MAF.
Thanks for the help so far
Old May 5, 2010 | 12:25 PM
Atomic's Avatar
Ok, I did the same thing with my setup since I exceeded the limit of the maf with the blower. Just install the 2bar map, flash in a 2 bar os, and unplug and remove the maf, you dont need to cut anything.
Old May 5, 2010 | 12:26 PM
JJB's Avatar
JJB
Delphi 2 bar - 12615136 (8.1L is GM PART # 9359409)
Delphi 3.3 bar - 09373269 or 12215049
Delphi 3 bar - 12223861 or 12219935(The GM 3-bar part #12223861 will need a new connector part #15305891)
1 BAR is for a normally aspirated engine
2 BAR will handle a forced induction up to 14.5 psi of boost
3 BAR will handle a forced induction up to 29.0 psi of boost
Here is the pin outputs for a 3 bar:
PIN A: ground
PIN B: signal
PIN C: power
Iam sure you will want youre ECM to read boost if anything for safety calcs...2 bar is a plug and play costs $65 bux ...your current map will not read any signifigant boost /,,,your tuner can convert absolute Manifold pressure through HP or whatever with the KAPA readings and formulate from tune from there ...
Old May 5, 2010 | 02:12 PM
BigKID's Avatar
How are you reading IAT if you removed the MAF and didn't splice in another IAT sensor?
Old May 5, 2010 | 02:49 PM
O.K I just went down to the parts store and bought a IAT sensor and looked at my MAF plug The wires I have are orange yellow blackW/stripe brown and pink Which wires will i need for the IAT there are two pins in the IAT, it is frome a 91 syclone. Thanks for the Help
Old May 5, 2010 | 02:50 PM
joeyc125's Avatar
11 Second Truck Club
I'm assuming he forgot to mention that the tvs blowers come with a built in IAT sensor, so you don't need to buy one. However you have to splice the wires from the factory harness.
Old May 5, 2010 | 03:05 PM
JJB's Avatar
JJB
not to highjack ....whats wierd is we tuned mine both ways and it had much better response/power through mass then SD + 2bar...the downside is when it ouflows you have to reley on O2.s and knock for most of youre safety ...plus of course my WB and NB ...
bearden86
26
Nov 15, 2015 03:58 PM
turbo6c3
Oct 5, 2015 06:11 PM
BlownHD
Oct 3, 2015 12:24 PM
Lthompson
Oct 2, 2015 12:45 AM
Rockrz
Sep 29, 2015 09:07 AM
