funny story but not really
Old May 5, 2010 | 08:41 AM
chevy_man2000's Avatar
Default funny story but not really
About a month ago I put a whipple on my pickup and i put on some 8.1 marine injectors to go along with it. when i started it for the first time it ran for about 10 seconds and i thought i saw a fuel leak so i shut it off and checked it and everything looked fine so i cranked it up again and it started hammering like crazy right away. It broke a rod and knocked a couple holes in the block and i was completely clueless of how this happened because there wasn't anything on top of the piston and there wasn't any ding marks. So i just thought that maybe water got in there once and bent the rod and it just decided to break once i put my blower on. Now i put a different motor in and was going to start it yesterday and when i checked the oil for the last time it looked funny and when i smelt it it reeked of gas. I pulled the rail and injectors up and put some rags down and turned the key on and on the cylinder that blew, the injector was stuck open and dumping gas. So now after one motor and 6 fresh quarts of royal purple I realize that its all because of that one injector. And i bought the injectors outside of an ebay auction so theres nothing i can do about that.
Old May 5, 2010 | 09:02 AM
MARK3406E's Avatar
We all have learning curves but that is a crazy one. So how did it run after the new injector?
Old May 5, 2010 | 10:38 AM
its not running yet because i figgured out the injector problem yesterday and i haven't found any yet
Old May 5, 2010 | 12:34 PM
JJB's Avatar
JJB
Man thats why I beleive WIDEBAND WIDEBAND WIDEBAND cheap insurance my friend //Iam also installing a narrow band on my pillar pod....so sorry that hurts
Old May 5, 2010 | 01:36 PM
350SS's Avatar
I don't think a wideband would have helped in this situation. If you're running big enough injectors, it will flow enough fuel to hydralock the motor on startup. I had a similar problem with a stuck injector, luckily during startup the flywheel broke while cranking but I still havent checked to see if I bent a rod or anything.
One way to avoid this is to have a fuel pressure gauge installed and watch to see if the pressure stays steady before startup. If it drops quickly, you obviously have a problem. Mine did this when my motor hydralocked, but since I hadn't dealt with this situation before I didn't think about it being a stuck injector.
Old May 5, 2010 | 03:01 PM
JJB's Avatar
JJB
good point that is very true ...i would think it would run just pig rich and smell like one too but yea i could think of a lot better ways to blow a motor ..
Old May 5, 2010 | 03:08 PM
yes that is exactly why i am putting a fuel pressure gauge in my pillar pod
Old May 5, 2010 | 03:53 PM
JJB's Avatar
JJB
Exactly I Run that , boost , and AFR
TrendSetter
Nov 26, 2018 07:18 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
jscherbs
Sep 30, 2015 07:54 AM
Benloe
Sep 22, 2015 10:24 PM
Alco
Sep 4, 2015 04:08 PM
