Problem w/ Intercooler Reservoir
Old Aug 2, 2007 | 08:02 AM
Bradazz's Avatar
Default Problem w/ Intercooler Reservoir
The last few days I have noticed a problem. Each time I am done driving my truck the water from the Intercooler Reservoir foams up and leaks out of the to down onto my front drivers side wheel. The water is leaking out of the top where the cap screws onto the reservoir. I have a Radix and I am using distilled water with one bottle of Redline water wetter. I am thinking it has something to do with the heat because this is the first time I have had this problem. Does anybody have any suggestions for a fix? Let me know.
Old Aug 2, 2007 | 09:27 AM
TrickTurbo's Avatar
Truck Sponsor
How hot is the water in that tank, and is the tank filled to the very top.?
Old Aug 2, 2007 | 09:32 AM
Bradazz's Avatar
I dont know the temperature of the water in the tank, It happens after I drive my truck around for a while. I do fill the water to the top of the tank but after a few days it goes down to half tank or less. How do I flush all of the water out the correct way? I can then refill with whatever you suggest I use?
Old Aug 2, 2007 | 09:36 AM
TrickTurbo's Avatar
Truck Sponsor
Man sounds like you have a leaky core or some serious over heating issues. Try to get ahold of Brian @ JPA he knows alot of those blowers.
Rick
Old Aug 2, 2007 | 11:14 AM
wkdivr's Avatar
There's a fill line near the top of the tank. You shouldn't need to fill too often. Mine needs a cup, or two once a year, or so. You might have a leaky core, or somewhere else.
Also, the water in the intercooler tank should be warm to the touch, not so hot you couldn't stick your finger in it.
Old Aug 2, 2007 | 11:39 AM
krambo's Avatar
I haven't had to top my intercooler off yet,...2 years and counting running 50/50 mix distilled and dex and 1 bottle of WW.
Old Aug 2, 2007 | 11:49 AM
BlownChevy's Avatar
blownerator
25 Year Member
You more than likely have a bad cap and or reservoir. PM me your address and I will have one shipped out to you asap.
BTW, put some coolant in your system. Water wetter is not going to do much for you at that low temperature.
Old Aug 15, 2007 | 08:45 PM
Bradazz's Avatar
Did you get the PM that I sent you? Let me know. Thanks, Brad
$A_Money$81
Mar 27, 2023 10:25 AM
turbo6c3
Oct 5, 2015 06:11 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
old motorhead
Sep 29, 2015 08:22 PM
