Pro Charged 2000 Suburban Interooler Fitment
Old Nov 10, 2020 | 01:58 PM
Pennywise67's Avatar
5 Year Member
Default Pro Charged 2000 Suburban Interooler Fitment
Anyone have GMT800 (2000-2006) Suburban, Tahoe, Silverado that running a pro-charger with 2 core intercooler and a Tru-cool 40K trans cooler? Any pics of how you fitted it? Any issues fitting both in there? Just trying to see if there is any issues or mods needed, before I start installing it. Thanks.
-Larry
Old Nov 12, 2020 | 08:03 AM
MikeGyver's Avatar
I made new mounts and use electric fans to move my radiator and condenser back four inches to use a four inch thick intercooler behind the hood latch support. The radiator mounts are L brackets upside down with holes in the top for the radiator bottom bushings. The brackets are bolted to the frame. The condenser is a little easier to move back, I had to weld new bottom mounts to where the radiator used to be, and fabricate new top brackets. Both required putting rivet nuts into the back side of the top of the core support. The one iffy thing is that I had to bend and re-angle the lines on the condenser.
Most everyone else simply cut the hood latch support and bolted it to the top of their intercooler.
Old Nov 12, 2020 | 08:05 AM
arthursc2's Avatar
I used an air to water instead, still required fab work but everything is in the OE location
Old Nov 12, 2020 | 08:30 AM
5 Year Member
Thanks all. So should it go trucool-Intercooler-Radiator in that order? Or intercooler in front of trans cooler?
-Larry
Old Nov 12, 2020 | 08:44 AM
arthursc2's Avatar
my heat exchanger is in the front of everything, but it is also only 1" thick, and my trans cooler is in the bumper. You can see the exchanger behind the grille. Pinch to zoom
Chevyguy02
Mar 9, 2017 10:53 AM
Mean Green z28
Aug 19, 2016 06:17 PM
oakley6575
Jun 20, 2014 10:32 PM
GAME OVER
Mar 2, 2005 07:05 PM
