Porting 317's for my setup
Old Oct 4, 2011 | 05:47 PM
sharpshooter's Avatar
Default Porting 317's for my setup
What would porting a set of 317's do for my setup below? No other changes-keeping ported 78mm tb, truck intake,trucker cam and exhaust as is.
What would hand porting a set cost? I'm just trying to see if it would be enough bang for the buck.
Now that I have the 80e I can start thinking about adding hp!
I might start by running a little more boost with a pulley swap but l was thinking heads would be next. Opinions?
Old Oct 4, 2011 | 05:52 PM
Mangled03gmc's Avatar
Baltimore Whore
As we know these heads flow very well to start.. I had my heads done at a local shop, that has some exp doing ls heads.. It is easy to mess them up, take to much out.. I would think with a little bit of bowl blending, port matching( which you can do your self) and a infinite angle valve job would free up a little bit of power.. I think I have 300 into mine.
Old Oct 4, 2011 | 06:18 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Smaller pulley and bigger exhaust would be my choice.
Old Oct 4, 2011 | 06:23 PM
Man I can't give up the corsa.
Old Oct 4, 2011 | 07:12 PM
1slow01Z71's Avatar
Then its going to hold you back. Atleast build a bigger y with a cutout and neck it down to the corsa. Back in the day charris blew his corsa apart in his h2 due to so much back pressure.
Old Oct 4, 2011 | 08:21 PM
02'Z71ONDUBZ''s Avatar
If your gonna do it I would have a set CNC'd. If you improved your y-pipe and added a big cutout, and paired it all with a 90mm tbss intake setup, I would expect you to gain at least 45-50rwhp
Old Oct 4, 2011 | 08:26 PM
Baltimore Whore
What size is your exhaust Russ?
Old Oct 4, 2011 | 08:50 PM
3" corsa catback with a magnaflow before and after the corsa,dumped above axle
the ory is the normal pacesetter 3"
Old Oct 4, 2011 | 09:56 PM
slowlsx's Avatar
i think stock48 hand ported his 317's on his old motor and gained about 40rwhp while dropping a few pounds of boost in the process. me personally i wouldnt get them cnc'd just hand ported.
Old Oct 5, 2011 | 09:55 AM
If I want to see how restrictive my exhaust is I could unbolt it from the y and run it. If it is a restriction should I see a drop in boost and the afr's lean out some?
