Porting 317's for my setup
Old Oct 14, 2011 | 06:46 PM
  #21
Rick_Vor's Avatar
Originally Posted by sharpshooter
Man I can't give up the corsa.
Run two Corsa's. I'm running dual 3.0" into a X-pipe into two 3.0" Random Technology SS ovals mounted vertically side-by-side. Nice and quiet for cruising with minimal back pressure. Roars to life when you're on it.
Originally Posted by 02'Z71ONDUBZ'
If your gonna do it I would have a set CNC'd.
2nd that. Today's CNC heads are so much more consistent port-to-port than hand ported heads. IMO, unless you pay top dollar, hand ported heads generally seem to lose low lift velocity (bottm end torque) due to "hogging out" the port to hit the big flow #. I'd pick up a set of used CNC heads (WCHH, AFR, etc) for a decent price, slap them on and recoup $250-$300 on your 317's. Plus CNC heads have a resale value if (when) you upgrade down the road compared to garage hand ported heads. That said, I've done about 5 sets over the years and it is a lot of fun and a ton of satisfaction doing it yourself.
Rick
Old Oct 14, 2011 | 07:27 PM
  #22
tarinitup's Avatar
9 Second Truck Club
Look for some used patriot stage 3s. I've see. I saw a few sets sell for 500-600 on ls1 tech and you should be able to get 200 or more for your stocks. People talk **** about them all the time but they flow good for the money.
Old Oct 14, 2011 | 07:46 PM
  #23
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Since you really dont want to give up the corsa, why not run ARH lts and where the Y merges use a flowmast 3.5" merge with a 3.5" cutout so when you really want to get on it you can open her up but still keep the corsa catback that you love.
Id do your exhaust and intake first unless you find a good deal on some nice heads.
Old Oct 14, 2011 | 11:03 PM
  #24
idahoblkss's Avatar
yeah the 80e defiantly beats your 60ft with a bat to a bloody pulp, but i think its worth it and like you said your trap speed goes way up!! my trap speeds are of those running 11.4-11.5 in most cases when i only ran a 11.8 its kinda cool. but i say just pulley it down and see where your at.
Old Oct 15, 2011 | 02:21 PM
  #25
Breeze's Avatar
11 Second Truck Club
You didnt gain much because you are intake limited. IE that 1900 is maxed out.
Stock48 gained 4 mph by porting his 317s and dropped a couple tenths. Many others have had the same results that werent intake limited. Id say with that D1SC he isnt at its limits so he should be fine. With that said, I think Id do a better intake system first, and get a better flowing exhaust before Id crack open the motor.
Like I said very little gain, Money is better spent on other upgrades. Btw I do run a 3.0 pulley.
Old Oct 19, 2011 | 11:05 AM
  #26
ShredSled's Avatar
I too am considering having a little headwork done to my 317's while they are off to replace my lifters... can't afford cnc heads though, but figured this would be the best time to do it so I don't have to spend double on these gasket kits....
but problem is finding someone near me to work them. hmmmm...
Old Oct 20, 2011 | 03:18 PM
  #27
charcold-bowtie's Avatar
If I had them off I would do it, but I wouldnt pull them to do it. I started to go through this this summer, even with the motor out IMO it wasnt worth it
Old Oct 20, 2011 | 05:48 PM
  #28
ShredSled's Avatar
think I'll be alright with oe lifters then??? the longblock I'm building has been sitting for probably about 2yrs, it's supposedly from an 05 Escalade that was totaled out around 60,000mi.
My budget is pretty tapped just doing a cam swap on it and basic refresh before I put it in the truck!
Old Oct 20, 2011 | 07:02 PM
  #29
TIM Z's Avatar
11 sec. Truck Mod
I bet youll be fine, wouldnt hurt if you have the heads off to pull the lifters and soak them in oil.
If you do have the cash get some LS7 lifters.
Old Oct 20, 2011 | 08:42 PM
  #30
I would put it in and run it. Dont fix what isnt broke and 60k isnt much IMO
