pcv "delete" change up with boost setup
Old Nov 2, 2013 | 11:00 AM
  #21
Choda's Avatar
Ferocity02 thank you for testing it. I am very surprised that the gauge didn't show any vac at idle and that exactly what we need. Our engines need a strong vac. Sounds like we need to use the manifold for outta boost vac. Still wonder if doing a 2 part system where in boost it pulls from the turbo inlet.
I agree, always use a check valve. bomba makes really nice ones.
Old Nov 2, 2013 | 12:37 PM
  #22
LS1TRUCKGUY's Avatar
i just have my drivers side valve cover ran to a vented catch can. its very simple and it works. a system set up to pull a vacuum on the crank case would be more involved, but it would be better.
Old Nov 9, 2013 | 08:25 AM
  #23
Noah Burns's Avatar
anyone know what that threaded bung in the 4.8L valley cover is for?
Old Nov 9, 2013 | 01:58 PM
  #24
Ferocity02's Avatar
Isn't that for the oil pressure sensor?
Old Nov 9, 2013 | 10:01 PM
  #25
damianldaigle's Avatar
Yes, that is the oil sensor bung, there is a spot on the front to hook a vacuum line. Mine came with a red boot on it.
Old Nov 9, 2013 | 10:41 PM
  #26
oakley6575's Avatar
That is only on the LS6 valley cover. Stock truck engines don't have the pcv port on the front.
mhorn0817
Jul 8, 2017 01:54 AM
D1SCSS
Jan 25, 2016 10:14 PM
The_W
Oct 28, 2015 09:00 PM
thunder550
Oct 8, 2015 04:53 PM
Mzay
Jul 6, 2015 11:03 PM
