My truck is off to shop #4
Old May 7, 2008 | 07:28 PM
  #241
Originally Posted by zippy
I'd go for something around a 220/224 or a 224/230. Comp has an off the shelf grind with a 224/230 on a 114LSA that might work for your setup. With that low compression I'd certainly be keeping your cam down to 230º or less.
i WILL be upping the compression though to either 9:1 or 9.5:1 Not sure which. I've been given varying opinions on the matter.
Old May 8, 2008 | 06:41 AM
  #242
zippy's Avatar
I'd go for the 9.5:1 myself.
Old May 8, 2008 | 08:30 PM
  #243
My IAT's scare me. they READ 90* as soon as I start the truck, even on a 30* day. They have READ well over 200* on the dyno.
given that, is upping the cr still suggested? I was told yes by others who I trust as well. I want to feel like I'm driving a 400hp camaro. Know what i mean?
Old May 8, 2008 | 09:09 PM
  #244
MikeGyver's Avatar
90° when the motor is cold in the morning, or is it measuring heat soak awhile after it ran?
As far as CR goes, I know for sure that 10.3:1 is too high.
Old May 8, 2008 | 09:12 PM
  #245
SincalT/A's Avatar
I think you really need to get the iat's under control first.Intercooler? meth whatch you got and what size?
Old May 8, 2008 | 09:14 PM
  #246
dewmanshu's Avatar
Moderately Differentiated
something is wrong if your IAT is 90* at start up, cold. 200* on the dyno. I know you don't want to hear that, but damn.
Old May 8, 2008 | 09:25 PM
  #247
kenne bell coolant reservoir, pump, intercooler, heat exchanger. It's a very similar setup to the Radix. My assumption is that most of the temp i'm seeing is heat soak. Charris and i have spoken about this. the iat sensor is in a bad spot. I DO need to get the filter to a cooler spot. This I know.
I'm told a larger reservoir, larger heat exchanger MIGHT lower the temps by a couple degrees. Not worth the pain in the *** for a few deg.
Old May 8, 2008 | 09:32 PM
  #248
SincalT/A's Avatar
What thermastat?Get that truck running cooler.I would not touch your setup till you get this under control.I don't think meth is going to help you unless you run a lot.
Old May 8, 2008 | 09:34 PM
  #249
SincalT/A's Avatar
Where's your filter located?
Old May 8, 2008 | 09:35 PM
  #250
filter right now is just about where the battery belongs. it's way too hot over there though. I need to finder a cooler place. The stock location seems to be the best but my battery is over there now. Maybe i'll move the battery back. I just didn't want to touch it. Too much **** attatched to it that i could screw up, lol.
