My truck is off to shop #4
Old May 8, 2008 | 09:37 PM
  #251
i think if i wrap those headers and get a cowl hood that will help to keep/get the heat out of the engine compartment too.
Old May 8, 2008 | 09:38 PM
  #252
ranwalk's Avatar
Originally Posted by DanaliHD
My IAT's scare me. they READ 90* as soon as I start the truck, even on a 30* day. They have READ well over 200* on the dyno.
given that, is upping the cr still suggested? I was told yes by others who I trust as well. I want to feel like I'm driving a 400hp camaro. Know what i mean?
If you are reading 90 degree IAT on a completely cold engine as soon as you start it on a 30 degree day I think its safe to say, that is not an accurate temp reading. It isnt possible to have IAT's that high on start up if its that cold outside. There is no way its even that warm under the hood on initial startup on a cold day like that. My Procharger with the air filter over the driver side header shows IAT's matching outside temp on a cold start.
Old May 8, 2008 | 09:39 PM
  #253
SincalT/A's Avatar
Let me geuss you are running open element filter in the engine bay.
Old May 8, 2008 | 09:55 PM
  #254
yup, exactly how kb designed it, lol. believe it or not
Old May 8, 2008 | 10:00 PM
  #255
MikeGyver's Avatar
... the iat sensor is in a bad spot....
I'm told a larger reservoir, larger heat exchanger MIGHT lower the temps by a couple degrees. Not worth the pain in the *** for a few deg.
If the sensor is not reading the post-aftercooler temperature, then why would you even think about improving the cooler's efficiency? Until you relocate the sensor to find out what the temperature of the air entering the engine actually is, all of the other questions you have seem insignificant to me.
Old May 8, 2008 | 10:06 PM
  #256
it is mounted in the intercooler but there is some question about how much of the temp shown is heat soak and how much is air temp.
Old May 8, 2008 | 10:11 PM
  #257
Justin @ EAD Performance's Avatar
The IAT senor is in lower intake manifold after the intercooler on the Kenne Bell kit. As long as the kit was installed correctly and thats the senor thats connected and not the one in the MAF. The IAT should be located on the driver side just behind the first injector in the lower intake manifold.
Old May 8, 2008 | 10:15 PM
  #258
yeah, what he said. lol. that's exactly where it is.
Old May 9, 2008 | 06:51 AM
  #259
BigCountryx's Avatar
This is exactly what I've been thinking. Can't be right to have +60* (30* AMB > 90*IAT ) on a cold start up
Old May 9, 2008 | 06:58 AM
  #260
Charris and I have spoken about it in the past. He stands firm on the fact that it is measuring the temp of the manifold due to the design of the port where the iat sensor is located. I've got to agree to an extent.
I was told on the dyno the temp at about 2000rpm was 170* and by 6300rpm it was in the 240* range. that's a big temp jump in 3 sec.
