My truck is off to shop #4
Old May 6, 2008 | 08:08 PM
  #231
Originally Posted by MikeGyver
What cam? How much compression? Please remind me.
235/235 @50 612 intake 612 exhaust 116 lobe separation in 2* advance 114 intake centerline
8.4:1cr
Old May 6, 2008 | 08:33 PM
  #232
Spoolin's Avatar
GFYS and STFU
Wow...that's as big as my turbo cam except it isn't reverse split. Pretty big cam there!!
Compression is ready for 20 lbs of boost or more!!
Old May 6, 2008 | 08:36 PM
  #233
I know, the cam has got to go asap. I'm open to suggestions on cam specs
Old May 6, 2008 | 08:46 PM
  #234
MikeGyver's Avatar
It would be easier to turn up the boost.
My cam seems nice: 222/224 @.050 115 LSA installed +4 degrees. Pulls good on the bottom and revs way out.
Old May 6, 2008 | 09:44 PM
  #235
BigTex's Avatar
Originally Posted by DanaliHD
... my low end sucks donkey nuts
Thats crazy. I would expect a 408 with positive displacement blower to have big honkin ***** down low.
I say start by taking care of the slipping trans before breaking into the motor. If its slipping, you'll have to fix it sooner or later. I'm not sure that the cam is really too large. Maybe its an issue coupled with the low compression, but it doesn't seem overly large for a 408.
Old May 6, 2008 | 10:19 PM
  #236
stock48's Avatar
9 Second Truck Club
That's a 6500+lb truck, I would think something 220ish .550'' on a 112 would be about right.
Old May 6, 2008 | 10:25 PM
  #237
Stoichiometric's Avatar
What do you guys think the effect of advancing the current cam further be? Closing the intake valve sooner should give a bit better response at low RPM, or is that a lost cause at 8.4:1 compression?
Old May 6, 2008 | 10:44 PM
  #238
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I had a 224 cam in my 420 IMO something close to that would be good. Along with a smaller pulley. What heads do you have maybe milling them with a different cam could make for one hell of a wild ride
Old May 7, 2008 | 06:13 AM
  #239
that's the plan. mill the heads to get me to 9:1cr. They are ETPerformance heads. I thought they were 245's but their website says 240. Someone suggested the 450hp Z06 cam would be great for me.
Old May 7, 2008 | 07:10 AM
  #240
zippy's Avatar
I'd go for something around a 220/224 or a 224/230. Comp has an off the shelf grind with a 224/230 on a 114LSA that might work for your setup. With that low compression I'd certainly be keeping your cam down to 230º or less.
