MP122 - What Compression?
Old Aug 5, 2008 | 06:12 PM
  #41
trever1t's Avatar
2nd fastest 5.3 ECSB
Originally Posted by Rick@Synergy
I am the one who is pretty much doing the tuning for Trever1T, and I can say they get pretty high during a full pass run because of his 3.0 pulley now. On the dyno they would start at about 108 and climb to about 165 when done. So yeah, its spinning pretty good.
R
Rick you do all my tuning...but the iat's do seem to stay a lot lower on the street than on the dyno. I haven't seen 140* yet but we'll know for sure soon enough.
Old Aug 5, 2008 | 08:13 PM
  #42
zippy's Avatar
R
Thanks for the info. I agree that with the 3.0" pulley he is now spinning it up into the heat range. How was his numbers with the 3.2"? Not picking, just curious.
Old Aug 5, 2008 | 08:20 PM
  #43
trever1t's Avatar
my IAT's were 140* at the end of a 1/4 mile run with or without nitrous. The new heat xr is 2x the surface area.
File Type: hpl
Old Aug 5, 2008 | 08:42 PM
  #44
zippy's Avatar
Thanks for posting that info. The L33 (I can't say enough about that engine) and the MP112 are a great combo. The Radix style blowers seem to work best with compression of around 10:1 (L33 is 9.9:1). This also answering the question at hand and post topic. If you look at the best responding Radix trucks they are often the LQ9 due to compression and cubic inch. Some say run as much boost as you can with your compression, I say run as much compression as you can with your boost.
Old Aug 5, 2008 | 09:53 PM
  #45
supersub's Avatar
Originally Posted by Slowhawk
Why do you think I'm all Turbo? 95% of the FI vehicles I do is Supercharged with even a small amount of Maggie's.(Yes,I do recommend them to certain goal's customers want).We built a 4.8 Maggie truck probly 5-6 years ago than ran 11.7's or .9's(I forget)So I'm pretty flexable.
We keep high regards to inlet temp/timing on vehicles and fully know the affects of them. I really want to know why the west coast has low temps and the east coast are high. 15psi over here is easy 200degree inlet temps from the Maggie location sensor which is a simple heat transfer from the compressed air.Then that is verified by the timing by getting KR and spark knock.
Yes, a Turbo or centrifical blower would put out the same high temp but they run A/A intercoolers which cut a ton of heat out.Then we run Meth just like the Maggies and see inlet temps drop dramaticly.2 days ago we dyno'd a 402ci with F1-c procharger (16lbs)on 93 and meth. Inlet temp started at 120 degree's and the end of the run was 65 degree's.
Maybe we are all overlooking a simple problem? Maybe the best thing is to send the blower back to be looked at?
Smack dab in the middle her in MN,and even i don't see Iat's anywhere near 200 deg,my combo is 7.0 liter's w/a 122hh on top pushin 14+ psi,and static comp is 10.1.
there has to be something missing. iat's in the 240's is huge and detrimental to making good power regaurdless of what FI is being used.
Old Aug 6, 2008 | 09:34 AM
  #46
Hawk179's Avatar
Thats even better then.
R
Old Aug 6, 2008 | 09:35 AM
  #47
Hawk179's Avatar
He changed too many things this time around to know the true difference from the old pulley to the new pulley. I would take a guess and say not much though if I had to do them side by side.
R
walledition
Feb 24, 2026 03:27 PM
zblee
Nov 11, 2015 12:41 AM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
