Magnacharger Pulley
Old Mar 21, 2007 | 10:04 PM
06GMC4X4's Avatar
Default Magnacharger Pulley
I have an 06' 1500HD with a 6.0L with the radix. Right now I have 6psi of boost with the 3.20 pulley. I have heard you can run 8psi on the stock 6.0L without any problems. What size pulley would I need to go with to?
Old Mar 21, 2007 | 10:28 PM
thunder550's Avatar
High on diesel fumes
2.8 should get you about 9 psi, depending on other mods. What else is done to the truck?
Old Mar 21, 2007 | 10:30 PM
06GMC4X4's Avatar
The only other thing I have is an X pipe with Magnaflow mufflers.
Old Mar 21, 2007 | 10:32 PM
thunder550's Avatar
3.0" will probably get you about 8 psi.
Old Mar 21, 2007 | 10:37 PM
06GMC4X4's Avatar
Is this going to make the truck need a tune? Or will the program that comes with the charger still work fine?
Old Mar 21, 2007 | 10:42 PM
thunder550's Avatar
You should really get a tune, I dunno how much boost the Magnacharger tune is good for.
Old Mar 21, 2007 | 10:49 PM
BigTex's Avatar
A 3.0" pulley is a pretty good choice. More power, but not pushing the Radix way past its peak output. Smaller pulleys give a bit more power, at the expense of greater heat.
Old Mar 21, 2007 | 10:51 PM
06GMC4X4's Avatar
That is what I figured. I'm just looking to add more power cheap. This is the first time I've messed with a supercharger and all I hear about is changing the pulley for more boost and more power. I was going to do that as long as I didn't have to start messing with everything else to make it run right.
Old Mar 22, 2007 | 04:58 PM
danv's Avatar
If your interrested I have both a 2.8 and a 3.0 Nelson pulleys, the 2.8 has never been used, the 3.0 is used. I've a 5.3L and will not be using them..My radix came off of a 6.0. Pm me if interrested
D
Vortec350ss
Jan 12, 2016 10:36 PM
Avalanche2002
Nov 30, 2015 07:31 AM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
