boost creep
Old Jun 13, 2015 | 03:53 PM
  #51
08DenaliT's Avatar
Yea marty at turbosmart is saying the gates are to small so he's sending me some 50mm ones that are going to be released at sema that are the same cap size as the 45 and stuff. So I'll be posting pics of the set up
Old Jun 13, 2015 | 05:08 PM
  #52
JordanH's Avatar
Restricted
That's awesome! Hopefully the 50's fix the issue! Can't wait to see the results after you get through tuning!
Old Jun 13, 2015 | 09:05 PM
  #53
Gadgetized's Avatar
If anyone was wondering about my truck, I never moved the reference line to the intake as the eboost2 instructions said boost only. I installed the eboost2 and used the two port, single solenoid, single turbo connection method (2). I was getting about 7 PSI of boost before the eboost2 was hooked up, and now I am holding pretty steady at 16 PSI. I might put a weaker spring in it as I wanted to leave around 12 PSI, and ramp the boost up.
Old Jun 17, 2015 | 03:40 PM
  #54
shuetuning's Avatar
You simply are not venting enough exhaust gas to regulate the boost down to 3psi in higher rpms. That is why you get similar boost at high rpms with the 7psi spring. If you really need to run just 3psi then you either need a bigger gate or different manifold design.
Old Jun 18, 2015 | 11:57 AM
  #55
08DenaliT's Avatar
Well I mean I can't really make a more effecient manifold design. But I am going to a bigger gate. Waiting for turbosmart to have it built will be using a new designed gate that will be released to the public at sema
Old Jun 19, 2015 | 05:56 PM
  #56
TrendSetter's Avatar
you can get weaker springs at the hardware store. I had really good luck putting in just enough spring to close the gate after pushing the valve by hand, then relying on my ams1000 to add boost from there. i could run zero with the ams off or as high as I wanted from there. i put the activation on a wot switch so it didnt cycle forever and run my compressor constantly
SS94S10
Jan 3, 2019 01:57 PM
MOBBN
Sep 22, 2015 08:07 PM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
06murder
Sep 4, 2015 03:54 PM
