boost creep
Old Jun 5, 2015 | 08:22 PM
08DenaliT's Avatar
Default boost creep
So I've been posting alot lately asking for advice got another question . So I have a 3 lb wastegate spring in my gates now and it will just keep creeping up to about 7psi no wheel spin but I cam watch the gauge climb smoothly to it. Wastegates are in the flow path there dumbed to atmosphere. And just hooked up to the pressure source.
Old Jun 5, 2015 | 08:41 PM
spike performance's Avatar
FormerVendor
what motor and wat wastegate ur using ?
Old Jun 5, 2015 | 08:42 PM
GMCtrk's Avatar
Spring rating need not correlate with what boost you're seeing.
Old Jun 5, 2015 | 09:25 PM
08DenaliT's Avatar
14 6.2 tein turbo 6267 comp turbo billet wheels billet centers with turbo smart 45mm gates I have a big build log on here. https://www.performancetrucks.net/fo...-build-534711/
And what do you mean gmctrk
Old Jun 5, 2015 | 09:57 PM
George C....'s Avatar
Formerly ScreamingL
wastegate spring isnt always the boost youll see, its a idea of what youll see
the entire combo will determine what boost youll see with said a 3lb spring that sees 7psi isnt a bad Psi
Old Jun 5, 2015 | 10:01 PM
08DenaliT's Avatar
Ok that was me cutting out of it at about 5400 I got another file to load and will make another pull to 6 to see what happens. I just didn't wanna have a design flaw or something. Goal was to run a super low boost in 1st and then rise each gear even in third at 50mph rol and 7 psi not all the way tuned it just goes allover the damn place haha
Old Jun 5, 2015 | 10:14 PM
JordanH's Avatar
Restricted
He was running 7lb springs a few days ago and seeing constant 7-8psi of boost, and showing spikes of 8.9psi when tires would break loose... And now with 3lb springs he's still seeing 7+lbs.
Old Jun 5, 2015 | 10:16 PM
08DenaliT's Avatar
Yea when it was in there I still never made a full pull got out around 5k.
Old Jun 5, 2015 | 10:17 PM
JordanH's Avatar
Restricted
Are You still running off straight spring pressure... Not using the boost controller?
Old Jun 5, 2015 | 10:29 PM
08DenaliT's Avatar
No boost controller till I figure what's going on.
