boost creep
Old Jun 6, 2015 | 05:34 PM
  #31
JordanH's Avatar
Restricted
Originally Posted by 08DenaliT
Ok so tried putting each gate to its own turbo didn't change anything. Then pulled springs out and it would start to make boost around 5k and went up to 1.5 by the time I got to right under 6k. Now have them to my vacuum manifold and it hit 7.9.
So with no WG spring it would build 1.5lbs of boost?
Old Jun 6, 2015 | 05:41 PM
  #32
JordanH's Avatar
Restricted
And for 3lb in the WG, you're running the brown/black color spring?
Old Jun 6, 2015 | 06:27 PM
  #33
08DenaliT's Avatar
Yea it went to 1.5 but that was at the top of rpm until there it was zero. And yes brown black
Old Jun 6, 2015 | 07:26 PM
  #34
JordanH's Avatar
Restricted
That's so strange! Did the guys at new era, and turbosmart have suggestions?
Old Jun 6, 2015 | 07:39 PM
  #35
08DenaliT's Avatar
Gotta wait till monday.
Old Jun 6, 2015 | 07:41 PM
  #36
08DenaliT's Avatar
But seems worse at the manifold vac source so gonna go back to the compressor. And this time take the gates off and inspect them.
Old Jun 6, 2015 | 08:53 PM
  #37
JordanH's Avatar
Restricted
The WG's don't need to see a vacuum source, just run them off the compressor housing fittings.
After taking the springs out (and knowing that your WG placement is good), the only thing I can think of is the WG's?... But what are the chances of getting a faulty WG... Worth checking out though.
The only lines I would run off the intake manifold are the boost reference for your boost controller and the lines for your BOV's
Old Jun 6, 2015 | 08:54 PM
  #38
GMCtrk's Avatar
With the spring out he's almost completely avoiding any boost.....the wastegates are working. Just need a different spring. Or for best control get a CO2 controller.
Old Jun 6, 2015 | 08:55 PM
  #39
JordanH's Avatar
Restricted
Just out of curiosity, when your running just the WG, without the controller, did you still have the lines hooked up to your WG from the compressor? Or did you disconnect all lines from the WG's?
Old Jun 6, 2015 | 09:02 PM
  #40
08DenaliT's Avatar
I knew I'd get alittle boost creep but with the 3psi spring I was hoping to stay at about 5 not the 7 it's hitting haha I'll see what turbosmart says maybe run 2 60mm gates and hood vent the bitcjes. Or fender. And I ran all new lines each time I have a few hundred feet of the push lock line.
