boost creep
Old Jun 6, 2015 | 09:04 PM
  #41
JordanH's Avatar
Restricted
Originally Posted by GMCtrk
With the spring out he's almost completely avoiding any boost.....the wastegates are working. Just need a different spring. Or for best control get a CO2 controller.
He did use different springs... At first 7lb and then put 3lb springs in and had the exact same results, and this was using just spring pressure to run WG's... No controller. With both spring variations he would see boost climb to 7-8.9lbs.
Old Jun 6, 2015 | 09:06 PM
  #42
JordanH's Avatar
Restricted
Originally Posted by 08DenaliT
I knew I'd get alittle boost creep but with the 3psi spring I was hoping to stay at about 5 not the 7 it's hitting haha I'll see what turbosmart says maybe run 2 60mm gates and hood vent the bitcjes. Or fender. And I ran all new lines each time I have a few hundred feet of the push lock line.
LOL! My vote is one on each fender! And just start the tuning at 8lbs!
Old Jun 6, 2015 | 09:07 PM
  #43
GMCtrk's Avatar
That's only 2 springs tried. He needs something lighter for less boost. Plus a spring isn't going to be exactly precise in controlling boost.
Old Jun 6, 2015 | 09:12 PM
  #44
JordanH's Avatar
Restricted
I know they're not exactly precise.... But do you not think a 3lb spring should see less boost, compared to a 7lb spring?
Old Jun 6, 2015 | 09:13 PM
  #45
GMCtrk's Avatar
Not necessarily. I already explained to you my situation where light and heavy spring give the same boost.
Old Jun 6, 2015 | 09:16 PM
  #46
JordanH's Avatar
Restricted
Okay.... Well I guess the thing to do would be try a 1 or 2lb spring?
Old Jun 6, 2015 | 09:39 PM
  #47
08DenaliT's Avatar
That's the smallest spring they have.
Old Jun 6, 2015 | 09:43 PM
  #48
JordanH's Avatar
Restricted
Yeah... I looked at their chart...
Maybe one of the gates are sticking, and not opening properly? This really makes no sense to me
Old Jun 6, 2015 | 09:51 PM
  #49
08DenaliT's Avatar
Yea gonna take them off to see tomorrow just to make sure.
Old Jun 13, 2015 | 03:08 PM
  #50
JordanH's Avatar
Restricted
Any updates? Did you figure out the boost creep/controller issue?
