90mm tb ? eldebrock intake ?
#104
Erik, do you know if i can just cut the stock metal fuel line and use those fittings you posted up? i could cut them prety low back there and clean it up nicely.[/QUOTE]
Mr. Parish, I think it is the mac tools or snap-on that has a new tool to make the special flare on the metal line that is used in the quick disconnect fitting on the factory lines. It is the neatest tool i have seen in a long time but it is a little pricy at just under 500 bucks. Napa sells a repair kit that we use in our shop to make the black plastic lines and I personally really like it becuase of the lack of heat held. This kit is much cheaper than the other so it is what ever works for you and your setup. Just a little shop info for you, keep up the good work and can't wait to see it in action.
#105
Originally Posted by parish8
the elbow has a thick pad on the back for drilling and taping in vacume line fittings
#106
How do I change this text
Originally Posted by Danville Performance
Parish, I don't mean to be a nit picker but I am a little worried about to brake booster fitting in the runner in#8 runner. Ford had a huge problem doing this on the late 80's to late 90's on the 5.0L 5.8L truck engines. They were having burnt pistons due to a lean condition on the cylinder that the brake booster was hooked to and the released a tsb on it to move it the the central portion of the manifold to fix the issue. I would move it to the center pad on the back of the elbow just to be on the safe side. I don't want to see something to happen to your motor, we are all in this together!
Seams how this intake is used to help equal out all the cylinders.
#107
Originally Posted by Wilde Racing
I was wondering about this too......
#108
#110
single digit dreamer
there is a check valve on that line going to the brake booster. anytime i am under boost there will be no flow. when under vacume there might be some flow but only when i stab the brakes. i dont think it is anything to worry about.
lots of bungs for lots of vacume/boost signals. one to the fuel presure reg. one to the old map(not sure if i even need that anymore), one to the new map, one to the hobs switch for the 2nd fuel pump, one to the boost controler.
