Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
gear on dyno
Old Jul 2, 2013 | 01:38 PM
tim wellington's Avatar
Default gear on dyno
does anybody know what difference if makes what gear dyno pulls are done at some people use 2nd other use 3rd
Old Jul 2, 2013 | 01:51 PM
thunder550's Avatar
High on diesel fumes
Generally you'll want to use 3rd or whatever gear gives you a 1:1 ratio to get a true picture of your engine's power.
Old Jul 2, 2013 | 01:52 PM
Chevy_King1500's Avatar
3rd gear locked is 1:1 for the 60e and 80e
2nd gear will give you an inflated number
Old Jul 2, 2013 | 01:59 PM
Default 2nd
that was my thought. i told my buddy
Old Jul 2, 2013 | 02:37 PM
slammedsilvy's Avatar
Some dyno in 2nd for fear of throwing the driveshaft at such a high speed.
Old Jul 2, 2013 | 03:26 PM
dirt track racer 81's Avatar
If your truck is fairly stock it may not even be able to make a 3rd gear pass or will take along damn time.
Old Jul 2, 2013 | 05:17 PM
dick_landy's Avatar
Got probably 100 pulls on mine in 4th (6L80E)
Old Jul 3, 2013 | 12:49 AM
oakley6575's Avatar
2nd won't give you inflated numbers... It will do just the opposite. Will show lower numbers than a 3rd gear pull. If your dshaft can handle the high mph, then pull it in 3rd. Like stated above though, some dyno operators won't even allow third gear pulls for safety reasons.
Old Jul 3, 2013 | 12:03 PM
Default gear dyno
my theory i have seen alot of 4l60&80 get stick 2nd & 3rd gear on the street .and with same power as before and wont even pull off .it easier to pull in 2nd ver 3rd (more power to pull off) i just had my turbo lq4 tuned and made more in 2nd than 3rd with same tune 30hp different .
Corvette454l88
Sep 1, 2016 01:24 AM
thunder550
Oct 8, 2015 04:53 PM
Greatdivider
Sep 9, 2015 09:52 AM
dselby25
Aug 24, 2015 07:26 PM
NuckenFuts
Jul 9, 2015 08:45 AM
