TIME SLIP DATABASE
Any 4x4's running 11's om notor?
Old Jul 6, 2012 | 03:05 PM
WHPLSH's Avatar
Default Any 4x4's running 11's om notor?
If you got one post up what ya got!
Old Jul 6, 2012 | 04:35 PM
AndysC3's Avatar
11s is a lot for all motor. I've gone 13.2@ 99.56 in mine. Not much more I could do na to get it faster. Unless I went with a 4k+ Rpm torque converter.
Old Jul 6, 2012 | 05:02 PM
darnie's Avatar
i once ran a 13.19 @ 99.57 hahaha ^^^^^ jk na hes right tho without being NA or having a beastly motor in a heavy 4x4 ur bout limited to that...
Old Jul 6, 2012 | 09:43 PM
WHPLSH's Avatar
Yeah its a feat but some one on here has to be in the 11'na?
Old Jul 6, 2012 | 10:12 PM
AndysC3's Avatar
Skeet is one of the only ones that I know of that is running in the 10s NA. But I believe he is 2wd.
Old Jul 7, 2012 | 04:46 AM
DTHPROOF's Avatar
I'm sure there's someone doing it, just not common.
Old Jul 7, 2012 | 08:20 AM
custm2500's Avatar
Ph.D. in HUBRIS
With a nasty 408 you might be able to run 11s if they truck is light weight aside from the 4wd. My rcsb 2wd should run mid to low 11s but it is a fairly radical 408 with 13:1 and a fairly large cam. It in a 4wd might crack 11?
Like anything it can be done but it will not be easier and you are going to spend an assload. Turbo a stock motor and you will be running 11s in no time at all. The turbo route is what I would do if I had it all to do over again. I can't wait to fire up my 408 and eventually dump 300 worth of nitrous down it's throat. But for the same or less money I could have turbo-ed the 6.0 and ran as fast.
Old Jul 14, 2012 | 08:43 PM
Link2603's Avatar
You can go over to silveradoss.com and there's a couple of guys running mid 12's, But 11's uh.....no
Old Jul 15, 2012 | 08:45 AM
Beatdown Z's Avatar
Laid Back
It would definitely take a lot of work. You'd want to start with a rcsb too, just for the weight advantage. I went 13.0 @ 101 with my ECSB with 9" of lift on 31" tires. Even if the truck was lowered and running light wheels/tires, I'd still have to change almost everything to even come close to an 11.99.
Oobray
Jun 13, 2022 03:38 AM
XL7
May 5, 2022 01:48 PM
ARC
57
Feb 21, 2022 10:54 AM
stealthperf
34
Feb 14, 2016 11:35 AM
thunder550
Oct 8, 2015 04:53 PM
