My ongoing 8.1 adventures...
Old Apr 30, 2013 | 11:36 AM
xx_ED_xx's Avatar
Default My ongoing 8.1 adventures...
Well as some of you may know my 04 1500 siverado has had an 8.1 since 08. First was a stock engine with a megasquirt then it was a slightly built motor and now it is this....
Old Apr 30, 2013 | 11:42 AM
Chevy_King1500's Avatar
looking great! what kind of numbers do you expect out of this?
top photos were teasing. it looked like an engine with just a different intake on it, i was hoping there was something else. lol
Old Apr 30, 2013 | 11:47 AM
xx_ED_xx's Avatar
all the same engine was doing alot of mock up the big throttle body setup is going back in truck with raylar long block. I have a t6 rear mount. it is going to get tuned with that setup, then imma work on fabbing up the twin setup in the truck.
I also am putting in a 1 ton corp 14 bolt new clutch and making updates to fuel system
The old setup with ported heads and zz502 cam made 640 rwhp and 680 rwtq on 6 lbs. Hoping for at least a 1000 rwhp with new motor. then put the twins on and see if i can squeeze some more out of it.
Old Apr 30, 2013 | 11:51 AM
Atomic's Avatar
I have a gauge for that
Just one problem, its not in the truck
Old Apr 30, 2013 | 11:53 AM
xx_ED_xx's Avatar
yup, working on it between playing army. you cant see the oil pan but it has been modified holds almost 3 gallons of oil
Old Apr 30, 2013 | 04:20 PM
Z71crawford's Avatar
Sorry for the stupid question but are you keeping the rear mount and putting twins on it? Would be a pretty bad *** setup.
Old Apr 30, 2013 | 04:31 PM
xx_ED_xx's Avatar
nah just doing twins, rear mount taking up alot of real estate under the truck etc
I am almost debating doing the twin 5 inch out out the hood and cutouts to run it thru a dual 4 inch system while cruising. Then if something happens while racing i can see it or not see depending how bad it is and blows all over windshield
Old Apr 30, 2013 | 05:19 PM
whippled 8.1l build's Avatar
looking sexy.. found out dart makes heads and blocks for it
Old Apr 30, 2013 | 05:20 PM
xx_ED_xx's Avatar
yeah iron and iron
Old Apr 30, 2013 | 05:23 PM
yup but they are borable to 4.6"
