At witts end!!!
Old Jun 29, 2007 | 05:40 PM
Lord Aries's Avatar
Unhappy At witts end!!!
OK heres the situation, my turck all of the sudden started running rough after sitting for about three days almost like a cylinder mis-fire... i am getting a Flashing Check Engine light while driving but, I am not getting any sotred codes! I checked vacum lines, no leaks...
I borrowed a buddy's laptop with HP Tuners ad was able to figure out how to do a Cylinder balance test and get 99/100% across the board... I do not know enough about HP Tuner though to really trouble shot with it... It is possible when the dyno shop tuned my truck that maybe they tuned off error code reporting???
I don't think its bab gas because i am not getting any pinging and I can get into full boost, it just runs rough... I need pull the plug wires on the turbo side to check for heat damage but, i don't think thats it because they wrapped in two layers of heat wrap...
I don't working on my truck but, damn do i hate trouble shooting this crap... Any ideas guys?
Old Jun 29, 2007 | 06:04 PM
Stoichiometric's Avatar
The flashing check engine happens during misfires. Probably a plug wire or two.
Old Jun 29, 2007 | 08:26 PM
Lord Aries's Avatar
Pulled a certian wire i suspeceted and it was burned... Rigged up a replacement and will test out in the morning...
Old Jun 29, 2007 | 10:12 PM
03sierraslt's Avatar
How did you do a cyl. balance test with HPTuners? I must be miss reading that statement...
Old Jun 29, 2007 | 10:15 PM
OLD BULL's Avatar
Probally a stupid question, but did you happen to move your O2 sensors by any chance? I recently had some experiance with this.
Good luck
Jason
Old Jun 29, 2007 | 10:19 PM
alanderson1978's Avatar
In VCM Scanner, go to VCM Controls, then the Special tab.
Old Jun 30, 2007 | 12:51 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Check to see if your P0300 series codes are turned off. P0300 is a random misfire and will cause the SES light to flash. P0307 for example would mean cylinder 7 has the misfire. Most likely a plug wire or fouled plug. Should be an easy fix. Good luck
Old Jun 30, 2007 | 06:42 PM
Lord Aries's Avatar
thanks guys, yea plug wire was damaged though two layers of head wrap...
GMCtrk
Jan 27, 2016 06:47 PM
zblee
Nov 11, 2015 12:41 AM
thompson
Sep 30, 2015 09:48 AM
lsxperformance
Sep 20, 2015 11:08 AM
11MPG
Sep 8, 2015 04:52 AM
