wideband setup questions
Old May 1, 2012 | 07:47 AM
topgun542's Avatar
Default wideband setup questions
Alright so I hooked up my wideband last night and I was just wondering if the radio power was a good source? I measured it and it was pretty constant. And when I drive the afr jumps from about 14.5 to 15.2... Is that normal? also when I got the bung welded in it was pit at about a 5 degree angle opposed to the 15 suggested... Should I have it redone? Thanks guys
Old May 2, 2012 | 07:54 PM
topgun542's Avatar
Bump for help
Old May 2, 2012 | 09:10 PM
darnie's Avatar
thats bout what mine reads.... then about dead nut 12.5 at WOT
Old May 2, 2012 | 09:14 PM
A Low Dime's Avatar
13 Second Truck Club
That generally the area for cruising. As long as it gioes down when at WOT.
IDK about the voltage of the radio harness being ok tho.
Old May 2, 2012 | 09:32 PM
1low05's Avatar
I would like to know too cuz i got my power from my radio but mine reads high 14's all the time cuz i need to retune it for my converter ...
Old May 2, 2012 | 09:43 PM
topgun542's Avatar
The radio seems okay for the few days ive had it... I wanted to hook it to a fuse box but I don't know how to write those... a walk through would be amazing
Old May 2, 2012 | 09:48 PM
ak2007r6's Avatar
Just get an add a fuse for the fuse box and wire it to something that has constant power even when the motor is cranking. On my 2011 it was labeled "Misc Ignition" I believe it was #43. I don't know what wire you tapped into for the radio but make sure it has constant power from when you turn the key and continues while starting.
As far as it jumping around that's normal. When cruising mine looks like a dancing light show, it's when you get on it that you want it to steady out at whatever you have your WOT AFR set at.
Old May 2, 2012 | 10:13 PM
darnie's Avatar
i got mine hooked up to the battery but have a fuse and a toggle switch easy enough
Old May 3, 2012 | 07:15 AM
topgun542's Avatar
Okay yea at wot its stable, ill go check out oreilys for a add a fuse kit thingy lol
Old May 3, 2012 | 09:11 PM
batboy's Avatar
11 Second Club
On my GTO, I used a tap-a-fuse on the windshield wiper circuit. The radio is fairly low amps. Ideal AFR when cruising is 14.7, you'll see it jump around low 14's to low 15's. No worries.
GXPJAY
Feb 13, 2022 08:15 AM
zblee
Aug 3, 2015 03:45 AM
USMCvet0311
Aug 1, 2015 07:45 AM
slowlsx
Jul 13, 2015 04:18 AM
