What do you think about shift points?
Old Dec 3, 2005 | 05:15 PM
thunder550's Avatar
High on diesel fumes
Default What do you think about shift points?
Mods are in my sig, I think I have the valvetrain to support higher shifts than my Nelson tune came with. What do you guys think? Would I gain anything?
Currently:
1-2 shift 5900 rpm
2-3 shift 5600 rpm
3-4 shift 5450 rpm
Old Dec 3, 2005 | 05:20 PM
99Silver6.0's Avatar
Currently:
1-2 shift 5900 rpm
2-3 shift 5600 rpm
3-4 shift 5450 rpm
Id take it a bit higher. Those RPM's seem kinda low.
1-2 shift 6300 rpm
2-3 shift 6200 rpm
3-4 shift 6100 rpm
Used those in my normal shift RPM @ WOT table.
Old Dec 3, 2005 | 07:15 PM
ap2002's Avatar
1-2 shift 6300 rpm
2-3 shift 6200 rpm
3-4 shift 6100 rpm
Old Dec 3, 2005 | 07:39 PM
SSlow 4.8's Avatar
lets see... heres mine:
1-2 @ 6400
2-3 @ 6500
3-4 @ 6100
so.. yes i beleive you can go higher... and thats on stock rods/bolts and the built tranny handels them nice and smooth, but its your call... i'd say bump it up a bit
Old Dec 4, 2005 | 05:48 PM
12sec.5.3's Avatar
Yes, they seem a bit low. I'd go at least 6200 on 1/2 and 2/3 for sure. You should feel a noticeable difference.
Old Dec 4, 2005 | 08:38 PM
thunder550's Avatar
1-2 shift 6300 rpm
2-3 shift 6200 rpm
3-4 shift 6100 rpm
I think I'll try this. Thanks guys!
Old Dec 4, 2005 | 09:17 PM
FILE's Avatar
What are the specs on the cam?
Old Dec 5, 2005 | 01:00 AM
thunder550's Avatar
210/218-551/551-116
Old Dec 5, 2005 | 06:35 AM
FILE's Avatar
You will be fine shifting in the 6200 to 6400 range.
210/218-551/551-116
Old Dec 5, 2005 | 10:50 AM
02sierraz71_5.3's Avatar
Id match it too your dyno Ive run my best times shifting just when the hp peaks. This is where a stall and good shift extension come in
Can you post up your graph?
