Undecided on cam selection for street/tow SUV 5.3LH6
Old Sep 22, 2017 | 09:08 AM
thebrain's Avatar
Default Undecided on cam selection for street/tow SUV 5.3LH6
Undecided on cam selection for street SUV 5.3LH6
This is a trailblazer that will be used primarily as a tow vehicle for my 3K LB boat (includes trailer).
What kindof power will these specs get me I just plan cam LTs w/ Y-pipe
LS1/2 Stage I Cam 223/230 .610"/.573" 115+2 made by comp cams
I could be using this cam for the DOD/AFM delete in 5.3LH6.
I’m planning a LS2 402CI build and think this would be a nice slethie cam to reuse.
1.power this cam makes w/ 5.3LH6 325ci
2.power this cam makes w/ 6.0LS2 402ci
I have a smaller spec’d cam in my WS6 it makes goobs of
Lowend torque just over idel.
Thanks for any good advice
Old Sep 22, 2017 | 01:21 PM
RPMSpeed Tech's Avatar
Truck Sponsor
That isnt a good tow cam for a 5.3 or 6.0. You should stay in the lower duration at mid 220s max exhaust and 214-220 max intake. Going more than that on an suv will take away the low range hp and tq. Youd want it cut on a 110-112 max. Any more wouldnt make good use of the intake and application.
Old Sep 22, 2017 | 01:48 PM
thebrain's Avatar
218/223 .598/.571 112+3 will the power be off idel?
I'm thinking this is a torquie cam.
https://www.briantooleyracing.com/cu...571-112-3.html
plus I can pick it as part of cam kit. for my dod/afm delete
Old Sep 22, 2017 | 01:55 PM
Truck Sponsor
We have afm delete kits more complete for less $$ than btr and the cams are easier on the valvetrain.
If you want a cam like that, our high lift hot cam will make as much power as that one and be eaiser to tune and drive especially on a stock stall converter. We can save at least $30 + over most competitors. And everything is on hand.
Old Sep 22, 2017 | 02:05 PM
thebrain's Avatar
got some links for
dod/afm delete
cam kits
Old Sep 22, 2017 | 02:53 PM
Truck Sponsor
Originally Posted by thebrain
got some links for
dod/afm delete
cam kits
Email me ill get you info
Rpmspeedtech@gmail.com
Old Sep 22, 2017 | 03:49 PM
thebrain's Avatar
pm me your price quote I"m leaning toward LS9 cam stock exhaust.
Old Sep 22, 2017 | 03:57 PM
FFDP's Avatar
You'd hate the LS9 cam, it is not made for a truck.
Old Sep 22, 2017 | 04:00 PM
Truck Sponsor
^ he is right its def not designed for a truck. The trucks have a max lsa even in stock form of 116. the ls9 cam has a 121. Def not designed for a truck and too much exh duration for a small engine.
Old Sep 22, 2017 | 04:07 PM
TXsilverado's Avatar
it's my opinion that there isn't a cam that will perform at part throttle towing than a stock cam...you MIGHT gain 5hp/torque at part throttle. get a blower if you need more grunt.
