Tuning WOT AFR
Old Mar 19, 2010 | 10:43 AM
00ChevyScott's Avatar
Wearin' da big hat
Default Tuning WOT AFR
I finally got my wideband working again not too long ago and noticed that at WOT my AFR starts in the low 12s and works its way all the way down to ~11.0 by the time it shifts. This is running quite a bit rich and would like to get it back up around 12.8 where it should be. What is the best/easiest way to lean it out progressively through the rpm band? The MAF table or work with the VE or PE tables? I'm pretty new at tuning but can read/learn whatever it is I need to read to get it figured out. If anyone has any quick suggestions or articles that could help with my situation, let me know
Also, while idling or regular driving, my AFR has a pretty large swing back and forth from mid 13s to mid 15s and is not consistent at all. Is this because of my cam or does my VE table need work there as well?
Old Mar 19, 2010 | 10:46 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
sounds like you need to do some OL tuning, your trims are over adjusting (idle)
Old Mar 19, 2010 | 01:14 PM
dewmanshu's Avatar
Moderately Differentiated
Is your WB setup for fast display or slow. Long slow sweeps may be due to too fast of a display rate and it is catching the oscillation of the fueling. As far as your cam causing it, easy to tell, is the "loping" of your cam and the wideband needle working together pretty much? Then yes.
Get you pcm into Open Loop and tune your MAF/VE table using the links in this section and or tuning websites. Keep in mind if your long term trims are adding 4% (example %) to adjust at part throttle then it will add 4% to your PE.
Old Mar 19, 2010 | 01:45 PM
BlackGMC's Avatar
Resident Retard
there is no helping you... basically your f***ed....
Old Mar 19, 2010 | 01:47 PM
BlackGMC's Avatar
Resident Retard
that is normal becuase you run in closed loop....
Old Mar 19, 2010 | 05:32 PM
00Silv4.8's Avatar
have a REAL tuner tune it!
Old Mar 19, 2010 | 06:19 PM
Atomic's Avatar
I have a gauge for that
log AFR error and apply changes to the maf table assuming you are still using the maf.
Old Mar 19, 2010 | 06:42 PM
dlt76028's Avatar
How did your afr get off so much? Didn't Charlie hook it to a wide band?
Old Mar 19, 2010 | 06:44 PM
Wheatley's Avatar
Truck Sponsor
Yes it was hooked up to my wideband,not sure how it is so far off now,but it is.LOL
Scott,text me later and I will help you out with it,it is very simple.
Aug 21, 2015 11:33 PM
ss4chad
Aug 15, 2015 02:25 AM
Ls3silverado
Jul 31, 2015 04:22 PM
GMCtrk
Jul 17, 2015 06:39 PM
lxcoupe
Jul 14, 2015 10:14 PM
