tuning for my stall?
Old Aug 21, 2009 | 09:01 AM
viciousknid's Avatar
Where's the Beef?
Originally Posted by 53RUSSELL
Why do you have to up the temp for having a stall. I would like see what you change the temp to as well.
My guess is that since it's stalling so much more than a stock verter would it's producing more heat so and the stock pressure vs heat settings cause it to apply/release when you're out of range.
Adjusting the pressure to make up for the added slip/heat allows it to stay locked when it needs to be?
Is that kind of right?
Old Aug 22, 2009 | 04:19 PM
Phantom's Avatar
11 Second Club
any other suggestions? any kind of throttle movement and it unlocks.
Old Aug 23, 2009 | 04:35 PM
Phantom's Avatar
11 Second Club
last night with the temps in the 60s we got the converter to lock with around a 60rpm slip(normal i suppose) today with temps in the mid 90s slip is bad again, not unlocking but slipping up to 700rpm.
stock trans with shift kit and 40k gvw cooler...any ideas? seems to be temp related
Old Aug 23, 2009 | 04:38 PM
00ChevyScott's Avatar
Wearin' da big hat
who built the converter
Old Aug 23, 2009 | 04:59 PM
BlackGMC's Avatar
Resident Retard
Since it seems to be Temp related you could try lowering your Force Motor Current table a very very little bit in the low TQ ranges for the tranny temps your seeing... Remember this table controls the pressure for the entire tranny. So increasing/decresing will affect everything... Also this table works backwards, a lower number increases the pressure, a higher decreases the pressure...
Old Aug 23, 2009 | 06:49 PM
dirt track racer 81's Avatar
its also started to shutter at higher rpm..whats the possibility that the tcc is bad?
Old Aug 23, 2009 | 07:07 PM
Where's the Beef?
If that's a loose as tyler says it is then I doubt you'll ever get it to work right.
Old Aug 23, 2009 | 07:13 PM
BlackGMC's Avatar
Resident Retard
A friend of mine had a similar problem his TCC would unlock really really easiely and eventually it stopped locking up. It ended up being a cracked TCC soleniod...
LCHEE
Oct 24, 2020 04:10 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
noproblems209
Aug 10, 2015 06:57 PM
Dirtywhite
Aug 5, 2015 04:10 PM
Castro45
24
Jul 31, 2015 07:13 PM
