Timing on cammed 6.0 and Shift points
Old Nov 22, 2005 | 10:14 PM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
Default Timing on cammed 6.0 and Shift points
new to hptuners and basically tuning..how must timing advance are most running on here...should i just keep turning it up in scan mode and see how high I can go without kr, then back it down a degree or two...second question is, if/when i do this, where do i go to make the permanent changes on the timing.
Also, my brothers SS has a somewhat small cam(218/222 ~560s) in it along with longtubes. The shift points were set at 5900, 5900 and 5850..I wanted to bump them up to around 6100, and see what happened. Is there anyway to do this while driving around in scan mode...When i do make these changes, like raising them to 6100, do i also need to change the mph the shift at, it would seem like i would have too because if i bump up the rpm, it seems like the other would need to change also.
Old Nov 23, 2005 | 10:17 AM
dewmanshu's Avatar
Moderately Differentiated
At WOT BOTH the shift speed(mph) and the rpm you set have to be exceeded before it will shift. Most people are happy with there speed, but like to bump the shift points. XLR8NSS just did this with a stock SS and found that it didn't like the higher shift points. https://www.performancetrucks.net/fo...d.php?t=353065
Tuning your advance is (IMO) a little more trickier than just adjusting the in scan mode. Use the help file in HPT 2.0 to get an idea of where you need to go. Exploring the software before you get to crazy with changes.
Old Nov 23, 2005 | 12:08 PM
BeefTip's Avatar
Yeah thats what i was figuring. In scan mode you can just bump up the timing all across the board but from what i have seen, in the edit mode you have to do it on the large grid...I have found some files of some cammed 6litrs and 5.3s that i might use to work off of. From what i have noticed from these other files, i think we have 4-8 degrees advance that i can play with.
Old Nov 23, 2005 | 12:35 PM
dewmanshu's Avatar
safely IMO, yes. Good luck.
Old Nov 24, 2005 | 12:06 PM
BeefTip's Avatar
thanks i need it!
ferrellrooster
Mar 6, 2025 03:22 PM
LCHEE
Oct 24, 2020 04:10 PM
OHsixLS3
Dec 27, 2016 09:30 AM
1979rs/z28
Sep 23, 2015 08:39 AM
ferrellrooster
Jul 17, 2015 07:07 AM
