segment swap issues 4l60e
Old 09-08-2018, 02:16 PM
85LSburb's Avatar
Default segment swap issues 4l60e
I am trying to apply a segment swap on my 85 burb with a 02 6.0 lq4. The truck had a 700r4 in it for years. Now i put a built 4l60e in it so i can have electronic control over the trans and converter. Got the transmission installed and running. Then segment swapped from a 02 camaro the transmission and transmission diag sections. That is all i changed. Flashed pcm and tried to start the motor. Would not start. Gave it some throttle and it started. I can not get it to idle with the segment swapped tune. If if put the old tune i had done years ago into it the thing runs great but the trans segment is not in it. I scanned it with the segment swapped tune in and the iac showes 0 counts at all times. What did it do wrong? Segment swapped tune is the one that says swap. Tune i had done years ago says pro tune.
File Type: hpt
File Type: hpt
chevyboi925
06-01-2016 10:47 AM
black04
115
03-10-2016 10:20 PM
Jetn3
23
11-23-2015 10:53 PM
GXPJAY
08-02-2013 12:09 PM
BetMinesFaster
02-19-2013 07:09 PM
Quick Reply: segment swap issues 4l60e
