Question about timing vs power
Old May 25, 2011 | 08:07 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
you ran at 8* when 'normal' is around 18*....you gave up a lot more than 30hp if your setup is anything at all like mine.
There's a point where added timing does no good but at 8* ... put it this way. I run a lot of timing on the street. My last time at the track I ran 2 11.41 runs...added 1 degree and ran 11.34.
1* mind you when I'm already running more than your norm on the street. I'd guess you left 100+ if your A/F is otherwise good
Old May 25, 2011 | 08:26 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by smokeshow
What was the DA at the track when you ran the 12.7?
Good question, I'll try to look it up when I get home.
Old May 25, 2011 | 11:45 PM
I used the calculator from dragtimes.
Density Altitude: 82 feet
Relative Density: 99.76 %
Old May 26, 2011 | 12:01 AM
TX Tahoe Z71's Avatar
I'm with Bill on this one, when Wheatley would add one or two degrees on mine, mid run, it was a noticeable change and immediately pulled harder, so ten would be a world of difference, I would say 70+hp
Old May 29, 2011 | 05:46 PM
Gh0st's Avatar
Jedi Master
You'd find your answer better if you went on a dyno to measure power output with multiple timing setups.
Old May 29, 2011 | 07:29 PM
To quote myself...
Originally Posted by AKlowriderZ71
I bet it's alot more than 30hp. The truck just layed down when it pulled the 8 degrees. I'll have it on a dyno on June 4th. Maybe I'll dyno it, then pull 8 degrees and dyno it again. That could be interesting, right?
Old Jun 1, 2011 | 08:34 AM
krambo's Avatar
Totally agree. On the dyno, (6.0L, mild cam, LT headers - free flowing exhaust, Radix with a 2.8, meth) My old set-up showed an increase of nearly 15RWHP per 2* of advance over 12* (~60RWHP difference from 12* to 20*). I lost HP after 20* and ran into "real KR" at 22*. This was from spark advance only...no other adjustments, 93 pump gas and 50/50 meth with the largest nozzel in the SNOW kit at the time.
ferrellrooster
Mar 6, 2025 03:22 PM
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
bsn1989
Jul 16, 2015 08:20 AM
1320Chicken
Jul 14, 2015 10:58 PM
