Here we go again
well my trucks been running great since ive changed the converter and put a flowmaster on it. but for some odd reason my fan only runs on high and my a/c pump isnt kicking on. So im dumbfounded to what it could be. I have a dual fan set up with a Nelson harness that ties into that lil green wire for the a/c and pin 42 on the comp. the truck was tuned for elec. fans. I checked every fuse every connection and cant figure anything out. Any one that could possibly through me a bone it would be great. thanks guys
I HAVE NO POWER AT THE A/C PUMP. check the connector with the key on the run pos. Nothing i took the fan outa the loop to see if that was the case nothing. so the fans in the right spot. Checked the pressure switches connections seem to be fine. Maybe im outa refrigerant :-(
