Ok Guys Got Hpt
Old Dec 13, 2007 | 11:46 AM
  #131
CHEVRACER83's Avatar
Originally Posted by truckmann
Still looks pretty conservative. I don't see any KR at WOT in the log. I would select that whole area in the lower right part of the spark table that has 21 in it and change that to ~26. Then smooth around it and log for KR. I also like to check the 3D chart and make sure the spark table isn't turing in to a lumpy mess.
HAHA.. DAMN... BUT I KEEP WORRYING ITS GONNA USE THE CRAPTACULAR LOW OCTANE SPARK TABLE... I LEFT IT ALONE BECAUSE I BELIEVE YOU OR SOMEONE TOLD ME OPEN LOOP USES THAT.... BUT HOW DO I KNOW THE CLOSED LOOP IS USING THE HIGH OCTANE TABLE
Old Dec 13, 2007 | 12:00 PM
  #132
truckmann's Avatar
If you look at your log you are getting ~21* of timing at WOT. If it was using only the Low table then you would only be seeing ~13* at WOT.
It's actually when the MAF is put into fail for tuning,which will cause open loop operation, that it will only use the Low table. It's a safety measure since the pcm thinks the MAF is broken when that is done. When in normal closed loop operation the low table is only used for blending when KR is detected.
Old Dec 13, 2007 | 12:44 PM
  #133
OH OK DAMN THANKS RYAN.... IM GONNA MESS WITH THE TIMING AT LUNCH
Old Dec 13, 2007 | 03:25 PM
  #134
OK DID THE TIMING ADJUSTMENTS... GOT A LIL KR UP HIGH... I COULD ACTUALLY HEAR LIKE A POPCORN SOUND... IM SURE THAT WAS KNOCK
Old Dec 13, 2007 | 03:27 PM
  #135
dewmanshu's Avatar
Moderately Differentiated
what octane are you using? QUALITY california gas.
Old Dec 13, 2007 | 03:28 PM
  #136
Yeah Wonderful California Quality Gas..
OH YEAH 91
Old Dec 13, 2007 | 03:29 PM
  #137
BUT CALIFORNIA 91 IS LIKE EVERYWHERE ELSE 87
Old Dec 13, 2007 | 03:37 PM
  #138
Here We Go... Did A Tune/log On Lunch
File Type: hpt
File Type: hpl
File Type: hpt
Old Dec 13, 2007 | 03:38 PM
  #139
The Bottom Is The Tune Where I Took A Lil Timing Out In The Trouble Kr Areas
Old Dec 13, 2007 | 03:45 PM
  #140
Should I Be Worried About The Rattling/popcorn Sound I Heard?
