No AC at idle or stop light
Old Jun 25, 2011 | 02:38 PM
Hawaiian_Built's Avatar
12 Second Club
Default No AC at idle or stop light
When driving around my ac is great but when I come to a stop, the idle drops to about 600-750rpm and ac no longer blows cold. I have to 2 foot it to get the ac back. Also happens when I remote start the truck hoping to enter a cooled vehicle.
My questions:
Is that too low of an rpm for the ac?
Where should the idle ideally be set to?
Old Jun 25, 2011 | 02:43 PM
08cheyennesc's Avatar
What's the voltage at idle.
Old Jun 25, 2011 | 02:47 PM
GMCtrk's Avatar
That's just one of the downsides of a clutch fan. The A/C shouldn't go completely warm, but it definitely will warm up if you're sitting at a light for a while.
Old Jun 25, 2011 | 04:25 PM
kazfan30's Avatar
I did not see above... efans or clutch fan? I have the same problem as well... and believe its that 1 fan alone in this heat is not enough to have proper airflow on the condenser...but once both come on....no problems cool anytime.
Old Jun 25, 2011 | 06:17 PM
andrew383's Avatar
traveling mod
If its a clutch fan truck id say the clutch is prob shot and needs replaced...
Old Jun 25, 2011 | 08:47 PM
12 Second Club
I believe its a clutch fan. I was also wondering if something in my ac systems was going out. I dont think my temp ever get to an alarming level.
Old Jun 25, 2011 | 08:52 PM
12 Second Club
My truck is stalled so bumping up the idle should help right? It would just suck cause i like how loppy it is at lower rpm
Old Jun 25, 2011 | 08:56 PM
12 Second Club
Battery voltage? I can check and get back to you.
Old Jun 25, 2011 | 09:00 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
It could be low on refrigerant. That's what I'd check first.
As for the fan clutch, unless it's hosed, that's probably not it. My a/c blows ice cold at idle(using a fan clutch). Besides that, if his fan clutch was bad, I'd expect him to have some slow speed and/or idling overheating happening. Especially in the summer heat he has. But there wasn't any mention of that.
Old Jun 25, 2011 | 09:02 PM
Remove throttle body and clean... You idle control is dirty and when ac tries to kick in... idle goes down to low for coompressor... I have seen it happen too many times and more often in drive by wire
