new tranny truck wont start
Old Jan 31, 2011 | 07:59 PM
xxbmxlsxx's Avatar
Default new tranny truck wont start
just installed a built tranny in my 04 yukon and having issues.
my friend had slighty shaved the starter wire by accident and it arced a bit when i tried to start the truck for the first time. i fixed that problem but now the truck just cranks and cranks no start. have fuel pressure but no spark. fuses all look good. any help would be appreciated
Old Feb 1, 2011 | 04:40 AM
1SlowHoe's Avatar
Destroyer of Transmissions
I can't think of anything in the trans wiring that would let it turn over but not crank. Any other work done at the same time? Maybe the coil packs were left unplugged?
Old Feb 1, 2011 | 08:47 AM
xxbmxlsxx's Avatar
didnt unhook anything but the tranny and transfer case. like i said my friend did ground the starter wire accidently, whiched shorted the first time i tried to start the truck. it just clicked and i saw a puff of smoke. i disconnected the battery again. pulled the starter. seperated the wires and taped them up where he shaved into the one and reinstalled. reconnected battery and now it just cranks and cranks. checked plug against block no spark. have fuel pressure on my gauge. fuses under hood look good and fuses on the inside driver side look good. any other fuses anywhere? im at a loss.....
guess i could pull everything back out and redo but jeeezzzus
Old Feb 1, 2011 | 12:12 PM
Chavette's Avatar
Suggestion: if you have access to a scan tool, check to see if you have any codes present. If nothing there, using the scan tool check to see if you get a rpm reading when cranking, if you don't then look hard at the crank sensor circuit and wiring. I would also double check all the wiring that travels together with the starter circuit wiring...you might find something fried. Damn I know that sux. Good luck.
Old Feb 1, 2011 | 03:01 PM
xxbmxlsxx's Avatar
thats what im gonna do today. hopefully its just a wire. its a freakin blizzard here in st louis so cant get my hands on a scan tool today. thanks for the advice
Old Feb 1, 2011 | 03:05 PM
Atomic's Avatar
I have a gauge for that
check the "PCM B" fuse in the underhood box
Old Feb 1, 2011 | 08:16 PM
xxbmxlsxx's Avatar
are there any wires on the back of the motor that pertain to ignition that i couldve pinched? i cant freaking find anything wrong.
but the sensor on the passenger side of the tranny on top by the servo is leaking fluid. looks like if you press it down it goes down into the tranny and i can pull it back up?!
Old Feb 1, 2011 | 08:35 PM
iamkeniff's Avatar
check ALL the fuses in the underhood fuse box, and id check the ones on side of the dash. id look into the IGN fuses, and the starter fuse/relay.
Old Feb 1, 2011 | 08:52 PM
xxbmxlsxx's Avatar
i checked each and every fuse, all good. starter is turning the motor just wont fire. im losing my mind
Old Feb 1, 2011 | 09:24 PM
Atomic's Avatar
Well fuel, spark, and air. The TB is probably a safe assumption that it works so air is covered. Are you getting spark? I know you said you have fuel pressure, but that just means your pump is working, are your injectors actually firing?
