Looking for some help: STS and a Tune
Old Apr 28, 2006 | 01:44 PM
Injected1's Avatar
Default Looking for some help: STS and a Tune
Ok, I am putting the 60-1 STS kit on my truck this weekend, unfortunately, my tuner has failed to send me a base tune to get my truck to his shop on. Can someone help me out with a tune to just so I can get the truck to my house, then to his shop next week?
Old Apr 28, 2006 | 02:02 PM
kbracing96's Avatar
If you don't change anything like injectors, then you will be fine to drive with the STS kit on to your tune as long as you don't get into boost. Do you have any tuning software?
Old Apr 28, 2006 | 02:17 PM
Injected1's Avatar
I have hptuners and we are putting on 42's
Old Apr 28, 2006 | 02:30 PM
kbracing96's Avatar
If your putting in the injector at the same time as the turbo, you just need to change the Injector Flow Rate table in your tune. What year is your truck?
Old Apr 28, 2006 | 02:39 PM
Injected1's Avatar
its a 2001 Truck...so i guess I just have to take it slow and easy, and no flashing the converter all the way out huh?
Old Apr 28, 2006 | 02:43 PM
kbracing96's Avatar
Ok, so you truck has a vac ref fuel pressure regulator, so you will just need to put 42 in the IFR table across the board. And as long as you drive it easy, you will be fine.
Old Apr 28, 2006 | 04:50 PM
quicksilverado's Avatar
You could leave the stock injectors in it and swap the 42s in when you are ready for the tune. It only takes about 30 minutes to swap the injectors. Then just stay out of boost until it is tuned.
Old Apr 28, 2006 | 10:42 PM
1slowsilverado's Avatar
Check your pm's
Old Apr 29, 2006 | 09:51 AM
Injected1's Avatar
Thanks 1 slow...I replied
The_W
Oct 28, 2015 09:00 PM
JFortner5
Aug 20, 2015 06:13 PM
jeff.ellis
Aug 18, 2015 10:34 PM
ZO6Ted
Aug 12, 2015 07:50 PM
Deceptarado
Jul 8, 2015 05:24 PM
