I Hate to ask but..
Old May 30, 2007 | 11:06 AM
jaegmc99's Avatar
Default I Hate to ask but..
Anyone have a 99-00 tune with only intake and exhaust for a 5.3l? I hate to sound like a dumbass but I can't find a tune without longtubes in the repository and I'd like to do better than 15.4 at the track this friday.. Oh yeah, Hp tuners. Please help me
Old May 30, 2007 | 12:09 PM
ridnlow's Avatar
wideband tune Ve and MAF, add some timing, dial in shift points, take out torque mangement and give it a run..
Old May 30, 2007 | 12:36 PM
jaegmc99's Avatar
I can't tune with my wide band because I didn't buy the "PRO" version of HPT The shift points were set at my last track day. Could I just bump up a few degrees of timing without the tables being set? Oh and which is the torque management that I can remove without hurting the engine? There is bunch of TM tables everywhere.
Old May 30, 2007 | 01:51 PM
Country Boy's Avatar
Senior Member
look for my 2004 5.3. Its a nice tune If you use it, let me know the results.
Old May 30, 2007 | 02:03 PM
nighthawk08's Avatar
look at the hptuners message board. there will be plenty of help there. there is also a way to get around not having the pro version to where you can still input the WBo2 sensor.
Old May 30, 2007 | 02:14 PM
ChevyThunder17's Avatar
It's not the engine that'll hurt when you remove TM, it's the transmission. If you read the help file that comes with HP Tuners, they show you where to turn off TM and Abuse Mode.
What sort of tuning have you done so far?
Old May 30, 2007 | 02:46 PM
nonnieselman's Avatar
What RPM you shifting at?
I was shifting at 6100 1-2 and 2-3 when i ran a 14.8.
But i dont know your elevations so a 15.4 might be pretty good over there..
Old May 30, 2007 | 02:50 PM
zippy's Avatar
I'm lost, your wideband doesn't work just because you can't hook it to your laptop?
Old May 30, 2007 | 03:07 PM
If he wants to correlate the WB data with the engine RPM, etc. is it a bitch to do without being in the pro version. Unless the WB has software capability and an RPM sensor.
Old May 30, 2007 | 04:23 PM
zippy's Avatar
I've used a handheld while tuning in trucks that are much faster than 15's. It can be done with a handheld.
