how lean
Old Nov 12, 2007 | 08:49 PM
southern_chevy's Avatar
Default how lean
Well I did some logging today and saw a commanded afr of 16:1 and well my WB said that it was right around there, so how lean will it start hurting it? This was at cruising speed and I just put on LT headers not sure what they will do to a tune but will they do this?
Old Nov 12, 2007 | 08:54 PM
dc_justin's Avatar
Hello Dave
At cruise, it's not a problem. You'll start to notice the power drop off above 16.5-17:1, but as long as the load is light, you're not going to do any damage.
Old Nov 12, 2007 | 08:56 PM
dirt track racer 81's Avatar
i got mine set at 15.6 now..used to have my 5.3 set to 16.5
Old Nov 12, 2007 | 09:02 PM
I guess better fuel mileage as well right? Also how close will the actual AFR follow the commanded?
Old Nov 12, 2007 | 09:06 PM
Here is the log for you EFI live guys
File Type: efi
Old Nov 12, 2007 | 11:03 PM
truckmann's Avatar
If it's tuned properly then the actual should be very close to the commanded. I have HPT so I can't look at the log. I had mine setup to run about 16:1 for a while with no problems. I'm running in now at around 15.5 at light throttle/cruise speeds.
Old Nov 12, 2007 | 11:04 PM
dc_justin's Avatar
Hello Dave
Sure you can. Anybody can download EFILive and view logs for free: http://www.efilive.com/download.aspx
Old Nov 12, 2007 | 11:07 PM
truckmann's Avatar
ahh yes very true... guess I'm too tired to think of that.... I even had it installed on here at one time...
dc_justin's Avatar
Hello Dave
Your commanded AFR is puzzling. Mind sending me your tune file? justin at blackbearperformance.com.
Old Nov 12, 2007 | 11:08 PM
dc_justin's Avatar
Hello Dave
