Failing to pass state car inspection
Old Jan 29, 2014 | 10:42 PM
coleton18's Avatar
Default Failing to pass state car inspection
I drive a 2004 GMC Sierra daily driver with a stock 5.3 and 4L60E tranny. I have had this problem the past year and now this year for my inspections. My truck is not modified besides the flowmaster muffler I welded on years ago...
The inspection sheet says:
1. 02 Sensor (NOT READY)
2, Evap (NOT READY)
3. Catalyst (NOT READY)
I have tried resetting my computer twice now by undoing the battery terminals and then driving the mileage. Both time i drove 300+ miles and still fail for the same reason...?
WHAT IS WRONG?! ANYONE ELSE HAVE THESE ISSUES?!
Old Jan 29, 2014 | 11:34 PM
LSX Power Tuning's Avatar
Are you its not tuned and the cats and rear o2's were deleted in the pcm?
Old Jan 30, 2014 | 09:06 AM
coleton18's Avatar
Oh yeah im positive, my father and I have owned the truck since 2004. Bought it brand new. We build custom classic cars and do some LSX swaps and pro touring chevelles and camaros. But have never had this problem before seeing that classics only have safety inspections no computer hookup...
Old Jan 30, 2014 | 10:03 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
"Not Ready" means that you're going in for the test too soon after clearing the DTC's. These OBD2 vehicles have readiness moniters.
Old Jan 30, 2014 | 10:14 AM
coleton18's Avatar
We drove for over 200-300+ miles after the first failing test and even disconnected the battery before driving that distance. Many people say they have these problems and just can't quite pin down the problem. ive done the freeway driving and its even 30 degrees here. (for the cold start portion of the testing) And im still getting theses things.?
Old Jan 30, 2014 | 11:10 AM
Right. Quit disconnecting the battery and quit clearing the codes. If your Check Engine light is coming on, fix the problem. There really isn't a way around the system, that's why it's like that. You can thank the GOV for that. Bottom line is, it's failing for a reason. Figure it out and fix it.
Old Jan 30, 2014 | 10:12 PM
coleton18's Avatar
Yeah i understand what you are saying but i have no codes or check lights coming on. and how am i supposed to pin down the problem if there is nothing to base it off of?
Old Jan 30, 2014 | 10:21 PM
Any chance you can read the PCM with HP Tuners or EFI Live, and post the file here?
Old Jan 31, 2014 | 12:03 AM
If you have access to a scanner go into mode $6 it may not throw a code but will abort running the rest of the monitors if there is a threshold min max value out in mode $6 it will say pass fail min max value. Also google GM drive cycle follow it accordingly to run o2 heater monitor engine needs to be cold start in morning turn on headlights and heater blower
http://service.gm.com/gmspo/mode6/
GMCtrk
Jan 27, 2016 06:47 PM
Wrecker 426
Oct 6, 2015 05:52 PM
Superman09
Sep 25, 2015 05:55 AM
Justin87gn
Sep 10, 2015 12:06 PM
