E Fan manual override
Old Oct 3, 2012 | 09:58 PM
TXSZ66AVLANCHE's Avatar
Default E Fan manual override
Installed a fan override in my 05 today, wired the relays so the switch is only operable with the ignition off. When ignition is on the fans operate as normal. Should be great to cool off faster between runs.
Old Oct 3, 2012 | 10:08 PM
black00chev's Avatar
Slowest turbo build ever!
I like this idea...
Can anyone tell me how to do this on my '00 with LS1 Fans and blackbear harness? I have the SoCal Diesel gauge mount with 2 auxiliary switches that I would like to use one for the fans.
Old Oct 3, 2012 | 10:21 PM
It's the same setup basically....just can't tell you for sure because I don't know the wire colors of the BB LS1 harness.
Old Oct 4, 2012 | 01:11 PM
Team Paulie's Avatar
Registered User
I did the same thing in my 04 when I did the E-fan swap.
Old Oct 4, 2012 | 02:21 PM
nonnieselman's Avatar
I have two switchs.. one for low and one for high..
black00chev..
you rem the two activation wires you hooked up? one to the PCM and maybe one to the AC signal?
Old Oct 4, 2012 | 02:35 PM
One switch, two relays to keep the low (green) and high speed (blue) wires separated. If tied together there is a CEL for FC relay 1, FC relay 2-3. Running two switches would eliminate the need for the relays.
I ran blue and green crosslink wire through the gas pedal harness grommet in the firewall, in the fuse box is the factory fan relay block. Spliced the added wires to the green and blue wires that trigger the fan relays. On 03-07 classic these wires only carry ground, flipping the dash switch turns on aux relays in dash to supply ground to the fan relays.
Old Oct 4, 2012 | 02:59 PM
black00chev..
Yea one is spliced to the AC signal and the other wire goes to BLUE42 in the PCM.
Right now my AC wire is taped to the wrong green wire (power source). So anytime the key is on the passenger side fan runs on high only.
The switches on my gauge mount are just rocker switches (on/off) with indicator. I think there are only 2 connections on each one.
Old Oct 4, 2012 | 03:11 PM
ok.. so your gonna need to redo your harness. unless you dont mind the compessor clutch engauging while your command your fans on
Old Oct 4, 2012 | 03:25 PM
Or...he could only wire the low speed relay.
Old Oct 4, 2012 | 03:29 PM
yep that works too.
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
TAPyvehc93
Sep 12, 2015 08:19 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
