Can some on look at this short tune file ?? EFI live
Old Jun 25, 2014 | 09:07 PM
Mangled03gmc's Avatar
Baltimore Whore
Question Can some on look at this short tune file ?? EFI live
I do not do tuning, but do have the stuff to log. I am not sure what is going on. This problem has been posted by other people in the past. This has begun happening more, more recently. At first it was only when it was cold, very humid or raining. As soon as I give it any throttle it instantly pegs 10 on the AFR gauge and some times actually fuels it so much it breaks up. Then it goes away. I have cleaned the maf, because it does get some oil on it from the blower ( Procharger says its not out of the norm ) So any way what is going on here. 02's Bad MAF, vacuum leak, or other ? I unplugged the MAF and the truck did the same exact thing as if there was no affect, so maybe bad maf.. Any info is great.. Thanks.. BTW this is a pretty much ruff in tune that I never had finished up for reasons.
Thanks
File Type: efi
Old Jun 25, 2014 | 10:30 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Bank 1 02Sensor never drops below like 600mv.
Either that sensor is bad or your constantly dumping alot of fuel on that side. Your LTFT is 25.
You want your LTFT to be around -3 to +3 range or as close to 0 as possible.
Old Jun 26, 2014 | 11:21 AM
Baltimore Whore
Ok so headed to get new 02 now.. Hopefully it does the trick. It has been getting worse for some time, with these being orig 2003 sensors its a good chance it is done, going to change both of them actually. Thanks
ARC
57
Feb 21, 2022 10:54 AM
Raggedz71
Jul 29, 2016 10:20 AM
shawn96gmc
May 17, 2016 04:15 PM
kr1s
Aug 24, 2015 05:34 PM
GMCtrk
Jul 17, 2015 06:39 PM
