A/c clutch issue on 02 silverado after tune
Old May 11, 2009 | 04:26 PM
86MC_SS's Avatar
Question A/c clutch issue on 02 silverado after tune
My a/c clutch will not stay engaged. I have enough refrigerant and all my a/c components are working properly. I know it has to do with my tune. I have been fiddling with the stall saver commands(per this thread) and it seems I only makes things worse whether I add or subtract from these tables. I did a search and have found nothing really helpful. At one point I thought I fixed the problem but I had not I have spent the last couple of days trying to figure out this problem but still am stuck.
I can use vcm controls in the scanner to force the compressor to stay on and then my a/c works perfectly because the clutch is forced to stay engaged. Is there anything I can do with Hptuners to force my clutch to stay engaged while my a/c is on?
I am on my wits end and want my a/c to work properly because California is starting to really heat up already:banghead:
02 silverado 5.3 mods: Comp Cam XR265HR 212/218 .522/.529 114LSA, Pacesetter LT's & ORY, Intake
Old May 11, 2009 | 04:29 PM
nonnieselman's Avatar
you tried to put your tune the way it was before the A/C problems started?
Old May 11, 2009 | 08:01 PM
86MC_SS's Avatar
Well after fiddling with more things and poking around with my light tester I have come to find out the low pressure switch off the dryer has no power. I checked all fuses and relays and everything works...I am looking for a a/c wiring diagram for an 02 5.3 but cant find a specific one. I found a 05 tahoe 5.3 a/c wiring diagram but it is not the same as mine.
Old May 11, 2009 | 08:06 PM
Parke10's Avatar
i was just about to say,check yer pressure switch,
Old May 11, 2009 | 08:15 PM
86MC_SS's Avatar
edit: anyone know what the resistance is suppose to be for the pressure switch? I want to test it just to test it but need to know what the resistance should be.
There is not any power going to the pressure switch...anyone run into this problem before? I have checked everything I know to check and am stuck. The relays and fuses under the hood and in the cabin are all good.
Old May 11, 2009 | 10:12 PM
86MC_SS's Avatar
I went ahead and replaced the pressure switch since it was not very expensive and it still does the same thing. It has to do with the tune
Old May 12, 2009 | 06:44 AM
Coban's Avatar
Just to make sure you know, and no offense intended, but the A/C compressor does cycle on and off when you have the A/C button on. Its not meant to stay on 100% of the time.
Feel free to correct me if I'm missing something.
Old May 12, 2009 | 09:34 AM
00ChevyScott's Avatar
Wearin' da big hat
The switch on the drier bottle is a high pressure switch, not a low pressure switch, and all it does is allow the current to pass through it if all is good. You can test this by jumping the connector with a paper clip.
Old May 12, 2009 | 10:42 AM
Tootall's Avatar
did you add any advace to the a/c bump when it enguages?
ferrellrooster
Mar 6, 2025 03:22 PM
Ketis
Jul 23, 2015 12:37 PM
bsn1989
Jul 16, 2015 08:20 AM
lxcoupe
Jul 14, 2015 10:14 PM
