Need a quick answer- pcm wires
Old May 12, 2009 | 04:22 PM
viciousknid's Avatar
Where's the Beef?
Default Need a quick answer- pcm wires
What gauge wires are on the PCM? 10 or 12?
I'm going to attempt to hook up valet mode today and I'd really rather not have to unhook the pcm just to see what size wire to get. Too difficult for me to get to it.
Old May 12, 2009 | 04:24 PM
nonnieselman's Avatar
more like 20 or 22.. its some small stuff.
Old May 12, 2009 | 04:25 PM
Where's the Beef?
wow. I thought they were a little thicker than that from last time I took it out.
Old May 12, 2009 | 04:26 PM
Where's the Beef?
as i look at this image close I think your right on that.
Old May 12, 2009 | 04:31 PM
last time i hooked up some Efans i just got some 18ga and soldered it to a PCM pin that i got from someone and the 18ga was larger than the wire on the pin.
Old May 12, 2009 | 04:41 PM
Where's the Beef?
Is the pin easy to get out? I was wondering about that.
Old May 12, 2009 | 04:48 PM
If you dissamble the connector its a piece of cake.
someone had send me some PCM Pins with about 6" wire attached. so i just soldered my wire to it and installed it. Didnt have to remove any.
ok well i did remove one after i put it in the wrong place.. haha. it was easy.
Old May 12, 2009 | 04:50 PM
Where's the Beef?
alright thanks.
I'ma run to napa and pick up some 18-20awg and a small switch.
Old May 12, 2009 | 04:51 PM
cool.. what kinda valet switch are you doin?
Old May 12, 2009 | 04:56 PM
Where's the Beef?
I'm gonna use it as an anti-theft. Probably just make it not start.
