Back to MAF - EFI
Where's the Beef?
Been running Mafless for a long time now. Was wondering what I need to reactivate in order to run Maf again.
Main reason being is cuz I'm tuned for 91 octane with 10%e85 and when I run 100% 91 fuel it runs richer.
Rather then switching between 2 tunes I'd like it to just make the adjustments.
Theres a good 1.5 AFR difference
Where's the Beef?
Cool thanks.
I'm hoping that will help with the fuel changes. If i'm running 10% e85 I have it usually cruises around 15.5 but when I put 100% unleaded it runs about 14.4-14.8 and that annoys me.
Hmmm, I don't think your MAF enabled/disabled has anything to do with your problem. I believe your trims would fix that issue, however you can't command 15.5 with trims enabled... IMO your best bet would be to reenable the trims and apply the lean cruise patch....
Where's the Beef?
I'm already running COS3. If I apply the patch wouldn't I need to divert back to the GM OS.
I'm still wanting to enable the MAF to see if it helps me any on my MPG's. But I'm getting tired of needing to add or subtract 3%+- from my VE table to get where I want depending on the fuel I run.
Where's the Beef?
No it's not flex fuel. but i've had best results at pumps running 10% E85. I figured the MAF would help a bit on days where the air isn't that great. I've seen it get richer on some days and leaner that same night. Unless it was my imagination.
ARC
57
Feb 21, 2022 10:54 AM
Raggedz71
Jul 29, 2016 10:20 AM
slowlsx
Aug 13, 2015 08:28 PM
