Help with EfiLive Spark tuning
I have looked and looked for a good write up on spark tuning with EfiLive. Everything says that it should be done on a dyno...which is fine. But i would like to get it close or within reason before jumping on the dyno. I have already tuned the truck pretty good fuel wise and the Ve table is almost spot on. Im running a COS3 and the mods in my sig. So if you guys can post up a good write up or give me a hand that would be great. Thanks alot.
Ok so WOT spark timing is just hit and miss. What about part throttle? Is there anything i can log like DYNCYAIR_DMA to help me see where im at in the spark table like in VE tuning? Im new at spark tuning so ill take all the help i can get guys
Also when adding spark should i be adding it to the High octane table and just subtracting 2 or 3 degrees from the Low Octane table? Do i do anything with the Optimal Timing table. Thanks
