5.3-6.0 wiring harnesses are they the same?
Old Jan 15, 2008 | 09:11 PM
mred's Avatar
Default 5.3-6.0 wiring harnesses are they the same?
i have located a motor and the 6.0 of coarse is the choice of all!!!!!
but it doesnt come with the wiring harness.
the 5.3 that is broke that has a complete harness,is all there nothing is missing?
thanks
Ed
Old Jan 15, 2008 | 09:16 PM
nonnieselman's Avatar
yea they are the same.... what year difference are we workin with here??
I swapped a 04 LQ4 in my truck and only thing i had to swap was the Oil Pressure Sensor..
Everything else is there..
Old Jan 15, 2008 | 09:22 PM
mred's Avatar
one is a 02 and the other is 99-01 i belive no more than 03 i know for sure.
whatcha think
thanks
Ed
Old Jan 15, 2008 | 09:27 PM
thunder550's Avatar
High on diesel fumes
You can use your existing wiring harness with no problems at all.
Old Jan 16, 2008 | 11:51 PM
desTRUCKtive's Avatar
If it is off an HD pick up the tranny connections are different (if it had a 4L80E) and the oxygen sensor hookups are reversed. Meaning if B1S1 O2 was female it is now male (something like that) but really not major issues.
Old Jan 17, 2008 | 12:52 AM
Wilde Racing's Avatar
How do I change this text
If it is FBW trottle body, just swap the 5.3s intake one the 6.0. Also like others have said the oil sensore may need to be changed.
Old Jan 17, 2008 | 08:53 PM
mred's Avatar
well the 6.0 is flbw but the 5.3 is not so i will just swap it all over.
now the o2 and tranny wires? are they different?
Ed
Old Jan 17, 2008 | 09:11 PM
thunder550's Avatar
Just keep your existing wiring harness in the truck and you won't have to worry about any of that.
Old Nov 4, 2019 | 08:49 AM
Matt Wicker's Avatar
Registered User
Default 5.3-6.0
I have a 2015 6.0 complete harness will it work on a 2000 5.3 engine? I have a 2015 6.0 complete wiring harness will it work on a 99 5.3 engine?
Old Nov 4, 2019 | 12:49 PM
1FastBrick's Avatar
Custm2500's Rude Friend
No. Different generation of engine.
